gas tank straps #71890
06/12/08 12:40 AM
06/12/08 12:40 AM
70duster340 Offline OP
Just wondering if there is anything needed to go between the straps and the tank on a 1970 Duster. I have removed and painted the tank, and removed, sandblasted, and painted the straps. The straps had undercoating on both sides when I removed them. Should I put anything on the straps to insulate them from the tank? If so, what would you all recommend?
Re: gas tank straps [Re: 70duster340] #71891
06/12/08 01:47 AM
06/12/08 01:47 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My tank and straps are metal to metal. Mike
Re: gas tank straps [Re: 70duster340] #71892
06/12/08 06:46 AM
06/12/08 06:46 AM
NW 'Burbs Chicago, IL
A_Roldan Offline
A_Roldan  Offline
I have seen (just recently) where there were strips of rubber trimmed and placed between the straps and the tanks. I would assume to cure or curb any noise from metal to metal contact. I saw it on the TV!
That's how I plan to do mine.
~Angel
Re: gas tank straps [Re: A_Roldan] #71893
06/12/08 12:58 PM
06/12/08 12:58 PM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
My straps came with a fabric that goes in between the straps and the tank. I think it is a good idea. less vibration of metal on metal even though tight. My originals didnt have it. 69 RR
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: gas tank straps [Re: 70duster340] #71894
06/12/08 03:51 PM
06/12/08 03:51 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
straps to tank are e,metal to metal. the big foam adhesive pad goes above the tank.
Re: gas tank straps [Re: mark7171] #71895
06/12/08 04:08 PM
06/12/08 04:08 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
straps to tank are metal to metal. the big foam adhesive pad goes above the tank.
Correct.
Re: gas tank straps [Re: 69Cuda340S] #71896
06/12/08 08:00 PM
06/12/08 08:00 PM
Thanks for the replies, folks. I know that it was, back in the day, metal on metal. However, since both the tank and the straps were painted, I thought it would be a good idea to possibly insulate the tank from the straps to do away with any scuffing of either the straps or the tank. I also think that metal against metal will eventually begin to squeak and/or grind. Maybe the idea of the door insulation was not so good, though. How would one attach rubber strips to the straps? I can get my hands on some rubber type sheets, just was hoping I could get some ideas from you all on how to glue or otherwise attach the rubber to the straps. I want the rubber to be basically hidden between the straps and the tank, if at all possible.
Re: gas tank straps [Re: 70duster340] #71897
06/12/08 08:41 PM
06/12/08 08:41 PM
S IL
1BaadBee Offline
1BaadBee  Offline
S IL
I use black felt paper - yes, that's the stuff you put on your roof before the shingles. I had it laying around and it seems to work well. Glue it on with 3M spray adhesive. Just my 2 cents worth.
Re: gas tank straps [Re: 70duster340] #71898
06/13/08 02:39 AM
06/13/08 02:39 AM
Canada
69 Dart Offline
69 Dart  Offline
Canada
On mine, I just laid down a couple strips of black electrical tape on the back of the straps. That way no metal to metal and you can't see it once the straps are tightened up. Best of all it doesn't scratch my nicely painted gas tank . . .
Re: gas tank straps [Re: 69 Dart] #71899
06/16/08 10:31 AM
06/16/08 10:31 AM
md
mopars4ever Offline
mopars4ever  Offline
md
What are you guys using to paint your tanks? I tried the eastwood tank tone and it scratches to easy. Mike
Re: gas tank straps [Re: mopars4ever] #71900
06/16/08 12:32 PM
06/16/08 12:32 PM
I used a flat black paint by Shermam Williams that is formulated for weather resistance. It's for boats, etc. I don't know if it scratches easy, as I haven't reinstalled the tank yet. I would also recommend Rustoleum. When it dries it's very hard and durable.
Re: gas tank straps [Re: mopars4ever] #71901
06/17/08 01:43 AM
06/17/08 01:43 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I use Eastwood Satin clearcoat. I like the natural look of the metal tank. The "Tank Tone" paint from Eastwood is a flat silver color that I have never seen on a Mopar tank before.
Re: gas tank straps [Re: Steve340] #71902
06/17/08 03:16 AM
06/17/08 03:16 AM
I used black roofing tar paper on top & some thick rubber padding between the straps & the tank. Not original but it's functional so I'm happy.
