Estimate on how much to mill heads? #718706
06/07/10 11:44 PM
06/07/10 11:44 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Even though when I bought my CNC Hughes Victors they said their work included milling the heads back to the original chamber size (75 cc is what Edelbrock advertises), they looked "big" to me. So, tonight I measured the two end chambers of one head and came up w/ 82 cc for both (fractionally more for the one chamber that shows more drop-out from the CNC program).
Can anyone give me a reasonable estimate of how much should be milled to reduce the chamber volume per 1 cc? Now that I know they're actually bigger, I think I'll just take 'em down to 78 cc, same as w/ my Stage VIs, and leave the CR at 10.8.
P.S. What got me thinking I needed to measure my heads was noticing that Hughes has recently changed their CNC Victor description to say their program increases the chamber size and for additional $ they'll bring the chamber down to what ever your target volume is.
I wonder at what point they realized that 75 doesn't equal 82?
Re: Estimate on how much to mill heads? [Re: BradH] #718707
06/08/10 12:06 AM
06/08/10 12:06 AM
Redding,CA USA
440charger500 Offline
Redding,CA USA
I think milling .010th is about -1.5 cc's. maybe someone else will chime in to verify it.
Re: Estimate on how much to mill heads? [Re: BradH] #718708
06/08/10 12:37 AM
06/08/10 12:37 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
level the cylinder head with an accurate level (machinist). fill the chamber with fluid to the volume you want the chamber to be. take a 0-1" depth mic that's been zeroed and place it on the head with the spindle just off the edge of the chamber. slowly turn the spindle down until the fluid just jumps up onto the spindle and take your reading. that is how much you need to cut the head to get the desired volume. if the mic is too close to the fluid level to get a good read you can put a spacer of known thickness (valve bucket shim, gage block etc.) under the mic and just subtract that from your reading.
Re: Estimate on how much to mill heads? [Re: jamesc] #718709
06/08/10 12:45 AM
06/08/10 12:45 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Good tip
Re: Estimate on how much to mill heads? [Re: rowin4] #718710
06/08/10 08:02 AM
06/08/10 08:02 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
My new indys were corrected back to 75cc brad and on the heads it said .020 was taken off to get them back to 75cc ..... also wallace has a calc for this
Mopar Performance
Re: Estimate on how much to mill heads? [Re: BradH] #718711
06/08/10 11:02 AM
06/08/10 11:02 AM
BradH Offline OP
BradH  Offline OP
I think Indy's spec of milling .006" for each 1 cc is close enough, considering they have similar chamber shapes and volumes --> 4 cc = .024"
Re: Estimate on how much to mill heads? [Re: BradH] #718712
06/08/10 02:02 PM
06/08/10 02:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
think it would need that much ? an open chamber 906 Rule of thumb is .005 for every 1 cc ????
Re: Estimate on how much to mill heads? [Re: JohnRR] #718713
06/08/10 03:20 PM
06/08/10 03:20 PM
UK
602heavy Offline
602heavy  Offline
UK
To get a set of Indy heads from 75cc to 66cc i had to cut .080" off the head.
Re: Estimate on how much to mill heads? [Re: JohnRR] #718714
06/08/10 03:23 PM
06/08/10 03:23 PM
BradH Offline OP
BradH  Offline OP
Think wide (open chamber) vs. deep (closed chamber).
Re: Estimate on how much to mill heads? [Re: JohnRR] #718715
06/08/10 03:25 PM
06/08/10 03:25 PM
jamesc Offline
jamesc  Offline
the indy chamber is smaller and has less effect when milled, with the 906 you're getting a lot of chamber reduction when cut.
Re: Estimate on how much to mill heads? [Re: jamesc] #718716
06/08/10 03:26 PM
06/08/10 03:26 PM
jamesc Offline
jamesc  Offline
UGH...treed again
Re: Estimate on how much to mill heads? [Re: jamesc] #718717
06/08/10 04:43 PM
06/08/10 04:43 PM
JohnRR Offline
JohnRR  Offline
That's right , for some reason I was thinking that the smaller chamber wouldn't need as much
Re: Estimate on how much to mill heads? [Re: BradH] #718718
06/08/10 05:42 PM
06/08/10 05:42 PM
BradH Offline OP
BradH  Offline OP
I was actually hoping it would take a LOT of milling to bring the chambers down. See, I had this little(?) problem last night where the head didn't stay put where I'd left it and... it landed on an OEM '70 4-bbl iron intake.
Naturally, it ended up chamber-side down, so there are some scratches and small gash marks on the surface that I'd like to see go away.
Re: Estimate on how much to mill heads? [Re: BradH] #718719
06/08/10 11:04 PM
06/08/10 11:04 PM
jamesc Offline
jamesc  Offline
Brad, depending on where the marks are i wouldn't sweat it. personally i try not to put the compression in the head but rather the piston, deck, gasket whenever possible. i hate cutting heads for CR.
Re: Estimate on how much to mill heads? [Re: jamesc] #718720
06/09/10 09:25 AM
06/09/10 09:25 AM
BradH Offline OP
BradH  Offline OP
Unfortunately, one of the "gashes" is right on the edge of the combustion chamber where the gasket "fire ring" would be.
Re: Estimate on how much to mill heads? [Re: BradH] #718721
06/09/10 10:34 AM
06/09/10 10:34 AM
JohnRR Offline
JohnRR  Offline
have it welded ?
Re: Estimate on how much to mill heads? [Re: JohnRR] #718722
06/09/10 10:59 AM
06/09/10 10:59 AM
BradH Offline OP
BradH  Offline OP
have it welded ?
If necessary... but I hope that's not required.
Re: Estimate on how much to mill heads? [Re: BradH] #718723
06/09/10 11:11 AM
06/09/10 11:11 AM
how about a large bore gasket like 4.560? it would also help lower the compression.
Re: Estimate on how much to mill heads? #718724
06/09/10 12:00 PM
06/09/10 12:00 PM
BradH Offline OP
BradH  Offline OP
I'll consider all options at this point.
Still feeling really STOOPID for having let the freakin' head fall over in the first place. Some things are so easily preventable... and yet they still happen.
