What is a good book on rebuilding big block Mopars? #718649
06/07/10 10:41 PM
06/07/10 10:41 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'm going to be rebuilding an engine myself for the first time and would like to know, what is a good step-by-step book to get on the subject of rebuilding big block Mopar engines?
Re: What is a good book on rebuilding big block Mopars? [Re: 1970RT] #718650
06/07/10 11:00 PM
06/07/10 11:00 PM
If it's going to be a relatively stock buildup I'd suggest this one:
http://www.amazon.com/Big-block-mopar-engines-Don-Taylor/dp/1557881901
I still use it as a reference while I'm building one so I don't forget anything.
Re: What is a good book on rebuilding big block Mopars? #718651
06/08/10 12:01 AM
06/08/10 12:01 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And I wouldn't use Don Taylor's book to start a fire...
Re: What is a good book on rebuilding big block Mopars? [Re: 1_WILD_RT] #718652
06/08/10 12:30 AM
06/08/10 12:30 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Care to enlighten us a bit more on your fire starting opinion?
I've got Don's book and although it certainly isn't perfect, I'm not aware of any other books that specifically tackle rebuilding a Mopar big block in step-by-step format. For a new engine builder who doesn't have someone to hold his hand it's not a bad option.
Maybe I should keep my opinions to myself until I figure out whether I can get mine back together and running again.
Re: What is a good book on rebuilding big block Mopars? [Re: rss] #718653
06/08/10 02:04 AM
06/08/10 02:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
& maybe I should keep my opinions to myself... But some of the stuff he suggests in his book I wouldn't do if I were rebuilding lawn mower.. It's been tears since I read parts of his book, so I won't try pointing out specifics but it's pretty shade tree... Back when I took JC courses on engine machining & rebuilding there were plenty of good books available, fact is most of the best tech books are written using Chevy & Ford engines as the guide, but the main info is good & you just adapt it to your needs..
Re: What is a good book on rebuilding big block Mopars? [Re: 1_WILD_RT] #718654
06/08/10 02:17 AM
06/08/10 02:17 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Its been TEARS since you read it?
Its not right to bad talk a book or person without specifics.
I have read the book and found it to be a decent guide to a novice builder.
Re: What is a good book on rebuilding big block Mopars? [Re: Kern Dog] #718655
06/08/10 02:35 AM
06/08/10 02:35 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah I didn't proof read.. Sue Me... The deal is there is plenty of good info, unfortunately there are some pretty blatant screw-ups.. If you don't know better the screw-ups get accepted... FWIW I just dug the book up, if I find the time I'll read through it & post a few things...
Re: What is a good book on rebuilding big block Mopars? [Re: 1_WILD_RT] #718656
06/08/10 06:42 AM
06/08/10 06:42 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: What is a good book on rebuilding big block Mopars? [Re: cogen80] #718657
06/08/10 09:44 AM
06/08/10 09:44 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Andy's book is not a step-by-step rebuild guide like the OP was looking for. He even states as much in the introduction section. Andy's book is focused on building 600 to 900 horsepower max. performance engines. Sure it contains some good relevant information, but 80+ percent of it is not going to help a guy doing a stock or mild street performance build.
FWIW, in the preface to his book, Andy recommneds "How to Rebuild Any Automotive Engine" by Barry Kluczyk as a step-by-step guide for new engine builders. However, I think his recommendation is more based on the fact that both his and Barry's book are by the same publisher. I bought Barry's book also, but I'd recommmend the Don Taylor book over it.
Re: What is a good book on rebuilding big block Mopars? [Re: Kern Dog] #718658
06/08/10 09:52 AM
06/08/10 09:52 AM
Middle of the mitten
69DodgeCharger Offline
I'd agree with that. Even though there is some things that are wrong info wise overall it is a pretty good basic book. As far as shade tree stuff my parents and granparents went to a guy (RIP Joe) that did a lot of that same type of stuff rebuilding engines and he was "the guy" to go to in the area if you wanted it run right and last. I"m guessing by shadetree you mean inspecting and re using parts? Or only replacing the parts you need?
Re: What is a good book on rebuilding big block Mopars? #718659
06/08/10 09:59 AM
06/08/10 09:59 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Actually, I am going to be building a stroked 400.
Re: What is a good book on rebuilding big block Mopars? [Re: 1970RT] #718660
06/08/10 10:11 AM
06/08/10 10:11 AM
AndyF Offline
AndyF  Offline
A stroker motor is a little different topic than a stock rebuild. My book and Chuck's book are the only two that cover strokers. Chuck's book is good but is a little over ten years old now so it doesn't cover any of the newer parts. The basics stay the same and he did a good job covering them.
If you go to Amazon.com and search for "mopar big blocks" you'll find at least 3 books on the subject. Amazon usually has a deal going where you can buy all three for $50. $50 is cheap compared to how much a stroker motor will cost.
Re: What is a good book on rebuilding big block Mopars? [Re: 1970RT] #718661
06/08/10 10:45 AM
06/08/10 10:45 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Buy Andy's book, Don Taylor's book, Chuck Senatore's book, Voegelin's blueprinting book and a few more, then spend countless hours on this board and talk to multiple engine builders and you should be in good shape.
Re: What is a good book on rebuilding big block Mopars? [Re: 1_WILD_RT] #718662
06/08/10 03:53 PM
06/08/10 03:53 PM
Sure, it's not perfect but it's great for the amateur. About the only thing I found blatantly wrong was the tightening sequence on the head bolts has, I believe, the #7 one repeated. It's a fairly obvious error even to the untrained.
Re: What is a good book on rebuilding big block Mopars? #718663
06/08/10 04:09 PM
06/08/10 04:09 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
My favorite mistake is the chart that lists the stroke of a 383 as 3.83
Re: What is a good book on rebuilding big block Mopars? [Re: rss] #718664
06/08/10 05:16 PM
06/08/10 05:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You can read all the books you want but there is no substitute for experience. Sure, it's nice to save the bucks BUT you'll spend every "saved" cent on tools you'll only use once and likely will still end up with something that's sub-standard. Read Andy's book, make a list of "particulars" and then take everything to a reputable shop and talk to the guy who's actually going to do the work. You likely won't be disappointed in the end and won't be second-guessing what you did.
Re: What is a good book on rebuilding big block Mopars? [Re: rss] #718665
06/08/10 06:02 PM
06/08/10 06:02 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have the book and it is relatively pretty good.. I believe that NO WHERE in the book did it discuss the distributor bushing that is sweged into the block.. Not knocking the guy but his background is the chevy rebuild books..
Re: What is a good book on rebuilding big block Mopars? [Re: 1970RT] #718666
06/08/10 07:20 PM
06/08/10 07:20 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I used Taylor's book, and it is a little vague here and there.
I have Andy F's and Chuck Senatore's too. Andy's right; buy all three as a package thing on Amazon.
Is there a video series out?
Only 1 book so i doubt there is one.
Re: What is a good book on rebuilding big block Mopars? [Re: Stanton] #718667
06/08/10 07:44 PM
06/08/10 07:44 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
You're right, with all the books and tools that I've bought I'll probably spend more doing it myself than if I paid someone else, but you don't learn much by paying others to do your work.
