Re: What is a good book on rebuilding big block Mopars?
[Re: 1_WILD_RT]
#718652
06/08/10 12:30 AM
06/08/10 12:30 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
And I wouldn't use Don Taylor's book to start a fire...
Care to enlighten us a bit more on your fire starting opinion?
I've got Don's book and although it certainly isn't perfect, I'm not aware of any other books that specifically tackle rebuilding a Mopar big block in step-by-step format. For a new engine builder who doesn't have someone to hold his hand it's not a bad option.
Maybe I should keep my opinions to myself until I figure out whether I can get mine back together and running again.
[Re: Kern Dog]
#718655
06/08/10 02:35 AM
06/08/10 02:35 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yeah I didn't proof read.. Sue Me... The deal is there is plenty of good info, unfortunately there are some pretty blatant screw-ups.. If you don't know better the screw-ups get accepted... FWIW I just dug the book up, if I find the time I'll read through it & post a few things...
[Re: Kern Dog]
#718658
06/08/10 09:52 AM
06/08/10 09:52 AM
Posts: 1,719 Middle of the mitten
69DodgeCharger
Its been TEARS since you read it? Its not right to bad talk a book or person without specifics. I have read the book and found it to be a decent guide to a novice builder.
I'd agree with that. Even though there is some things that are wrong info wise overall it is a pretty good basic book. As far as shade tree stuff my parents and granparents went to a guy (RIP Joe) that did a lot of that same type of stuff rebuilding engines and he was "the guy" to go to in the area if you wanted it run right and last. I"m guessing by shadetree you mean inspecting and re using parts? Or only replacing the parts you need?
#718659
06/08/10 09:59 AM
06/08/10 09:59 AM
Posts: 939 Metro Detroit
1970RT
Metro Detroit
If it's going to be a relatively stock buildup I'd suggest this one:
Actually, I am going to be building a stroked 400.
[Re: 1970RT]
#718661
06/08/10 10:45 AM
06/08/10 10:45 AM
rss
Seattle, WA
Buy Andy's book, Don Taylor's book, Chuck Senatore's book, Voegelin's blueprinting book and a few more, then spend countless hours on this board and talk to multiple engine builders and you should be in good shape.
[Re: 1_WILD_RT]
#718662
06/08/10 03:53 PM
06/08/10 03:53 PM
http://www.amazon.com/Big-block-mopar-engines-Don-Taylor/dp/1557881901
I still use it as a reference while I'm building one so I don't forget anything.
Sure, it's not perfect but it's great for the amateur. About the only thing I found blatantly wrong was the tightening sequence on the head bolts has, I believe, the #7 one repeated. It's a fairly obvious error even to the untrained.
#718663
06/08/10 04:09 PM
06/08/10 04:09 PM
rss
Seattle, WA
My favorite mistake is the chart that lists the stroke of a 383 as 3.83
[Re: rss]
#718665
06/08/10 06:02 PM
06/08/10 06:02 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I have the book and it is relatively pretty good.. I believe that NO WHERE in the book did it discuss the distributor bushing that is sweged into the block.. Not knocking the guy but his background is the chevy rebuild books..
[Re: Stanton]
#718667
06/08/10 07:44 PM
06/08/10 07:44 PM
rss
Seattle, WA
You can read all the books you want but there is no substitute for experience. Sure, it's nice to save the bucks BUT you'll spend every "saved" cent on tools you'll only use once and likely will still end up with something that's sub-standard. Read Andy's book, make a list of "particulars" and then take everything to a reputable shop and talk to the guy who's actually going to do the work. You likely won't be disappointed in the end and won't be second-guessing what you did.
You're right, with all the books and tools that I've bought I'll probably spend more doing it myself than if I paid someone else, but you don't learn much by paying others to do your work.
