built 426 hemi what oil to use? #718344
06/07/10 02:03 PM
06/07/10 02:03 PM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
I have a built 426 hemi with a roller cam. This is street/strip car that will never see cold weather. Im still going to use the zinc additive even though its a roller cam. Any sugg. on what oil to use? I have acess to 15w40 diesel hp oil and 5w30 synthetic but would like a recomendation. Thanks
Re: built 426 hemi what oil to use? [Re: ts70rt] #718345
06/07/10 02:10 PM
06/07/10 02:10 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I would vote for Valvoline VR-1
Re: built 426 hemi what oil to use? [Re: ts70rt] #718346
06/07/10 03:07 PM
06/07/10 03:07 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
I have the same setup, modified Hemi with roller, Vavoline VR1 10-30 is great. If I didn't have cold weather - or - I raced more, I would use the 20-50.
Can you talk to the engine builder to ask for their recommendation?
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: built 426 hemi what oil to use? [Re: 68X426] #718347
06/07/10 04:19 PM
06/07/10 04:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Been using 10W-30 in mine for 25 years now. Solid lifter car, so nowadays I add some GM break-in lube for the zinc.
Re: built 426 hemi what oil to use? [Re: topside] #718348
06/07/10 06:33 PM
06/07/10 06:33 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
Were running 10W-30 Brad Penn
Re: built 426 hemi what oil to use? [Re: topside] #718349
06/07/10 06:41 PM
06/07/10 06:41 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
i've a got a hemi with a roller too and I've been using valvoline 10-30 (as recommended by my engine builder)
Re: built 426 hemi what oil to use? [Re: Slipknot440] #718350
06/08/10 01:36 AM
06/08/10 01:36 AM
ts70rt Offline OP
ts70rt  Offline OP
10w30 seems to be the oil, would it hurt to use 15w40?
Re: built 426 hemi what oil to use? [Re: ts70rt] #718351
06/08/10 05:58 AM
06/08/10 05:58 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My 528 runs a flat tappet solid, I've been running shell rotella 15/40 heavy duty diesel oil since it was first fired 4 years ago. Dave
