Is 40 micron filter to fine between tank and pump? #718198
06/07/10 10:29 AM
06/07/10 10:29 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I need to install a fuel filter between the fuel cell and BG280 fuel pump. Is a 40 micron filter to fine? I'm using VP 110 race gas will a filter that says gas only work with this type of fuel? Should I stay away from paper type elements
Re: Is 40 micron filter to fine between tank and pump? [Re: flatiron] #718199
06/07/10 10:33 AM
06/07/10 10:33 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I ran a paper element with race gas for years with uot issue. I think the only time you "NEED" a SS one is when running alky.
Re: Is 40 micron filter to fine between tank and pump? [Re: flatiron] #718200
06/07/10 10:37 AM
06/07/10 10:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a brass screen type filter to get any of the
larger items then then the finer filter after the pump,
pumps dont like to suck so dont add any restriction
Re: Is 40 micron filter to fine between tank and pump? [Re: WILD BILL] #718201
06/07/10 10:40 AM
06/07/10 10:40 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thanks. How about the Micron size?
Re: Is 40 micron filter to fine between tank and pump? [Re: flatiron] #718202
06/07/10 11:15 AM
06/07/10 11:15 AM
Call Barry Grant and ask them what size to use in front of the pump. There (BG) paper element fiters are 10 micron, way to small for most electric pumps according to Magnafuel I switch from the BG 500 filter to a 100 micron in line and my AFR went richer at WOT
Re: Is 40 micron filter to fine between tank and pump? [Re: Cab_Burge] #718203
06/07/10 11:23 AM
06/07/10 11:23 AM
PA
moparacer Offline
moparacer  Offline
PA
I run a system 1 with a 30 micron between the tank and pump with no problems.
Plenty of flow
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Is 40 micron filter to fine between tank and pump? [Re: flatiron] #718204
06/07/10 11:47 AM
06/07/10 11:47 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
From RobbMc (Moparts member and designer of the Mallory Gerotor pumps and regulators and now his own products. http://www.robbmcperformance.com/products.html )
100 Micron Filters
Designed for use as prefilters for mechanical pumps and rotary vane style electric pumps.
40 Micron Filters
Designed for use as prefilters for gerotor style electric fuel pumps. Also used to filter fuel before it enters the carb.
10 Micron Filters
Designed to filter the fuel after the pump, before it enters fuel injectors. Not intended for use in carbureted systems. DO NOT USE AS A PUMP PREFILTER.
