Re: Is 40 micron filter to fine between tank and pump?
[Re: flatiron]
#718200
06/07/10 10:37 AM
06/07/10 10:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a brass screen type filter to get any of the larger items then then the finer filter after the pump, pumps dont like to suck so dont add any restriction
[Re: Cab_Burge]
#718203
06/07/10 11:23 AM
06/07/10 11:23 AM
Posts: 2,497 PA
moparacer
PA
I run a system 1 with a 30 micron between the tank and pump with no problems.
Plenty of flow
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: flatiron]
#718204
06/07/10 11:47 AM
06/07/10 11:47 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
From RobbMc (Moparts member and designer of the Mallory Gerotor pumps and regulators and now his own products. http://www.robbmcperformance.com/products.html ) Quote:
100 Micron Filters Designed for use as prefilters for mechanical pumps and rotary vane style electric pumps.
40 Micron Filters Designed for use as prefilters for gerotor style electric fuel pumps. Also used to filter fuel before it enters the carb.
10 Micron Filters Designed to filter the fuel after the pump, before it enters fuel injectors. Not intended for use in carbureted systems. DO NOT USE AS A PUMP PREFILTER.
