How to paint new organisol over old organisol #71797
06/11/08 11:44 PM
06/11/08 11:44 PM
Anonymous OP
Anonymous OP
Old organisol was painted in 1993 and it was probably the old lacquer (if thats what you could get from year one back then). New organisol from Totally Auto is enamel.
I know enamel over laquer is very very bad and wont work. What do you put down on top of the laqcuer to make sure the enamel doesnt lift
Re: How to paint new organisol over old organisol #71798
06/12/08 12:29 AM
06/12/08 12:29 AM
New York, USA
Chargerfan68 Offline
New York, USA
What I would suggest is to scuff/wetsand the old organisol good, and then spray one or two coats of Black PPG DP90 epoxy primer over that. Then within one day to one week, spray the new organisol.
The reasons why I use the black epoxy are due to the incompatibility issue, and the new organisol (at least the one I used) is not fuel tolerant and will become disrupted with a fuel spill. The black epoxy primer combats against bleeding through to the undercoats and it is the most unoticeable since it is similar in sheen and color.
Good luck to you,
Greg.
Re: How to paint new organisol over old organisol [Re: Chargerfan68] #71799
06/12/08 08:14 AM
06/12/08 08:14 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
you can spray enamel paint over lacquer paint without problems. it was done all of the time in the old days.
when you spray lacquer over enamel that's when you have lifting problems.
spraying DP down first is a good idea. it will help keep the enamel from soaking into the lacquer.
perception is 90% of reality
Re: How to paint new organisol over old organisol [Re: Chargerfan68] #71800
06/12/08 09:21 AM
06/12/08 09:21 AM
Spring, Texas
RedFish Offline
super street
RedFish  Offline
super street
Spring, Texas
This is how I did mine.
Howard
You don't stop playing games when you get old, You get old when you stop playing games.
Re: How to paint new organisol over old organisol [Re: Mr T2U] #71801
06/12/08 01:57 PM
06/12/08 01:57 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
This is correct.
Problems occur when you spray those "hot" lacquer solvents over enamel. Not the other way around.
Re: How to paint new organisol over old organisol [Re: Aero426] #71802
06/13/08 11:52 AM
06/13/08 11:52 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Always read the tech sheets. Here's a quote:
"When [DP90] is sprayed over lacquer substrates or basecoat that is not crosslinked,
and then allowed to set overnight before applying another coat of primer or a topcoat,
lifting can occur. This can be avoided by applying the DPLF Epoxy Primer, color and
clear coat in the same day or by adding 5% of DX57 RTS DBC."
...and the link:
DP90 tech sheet
Re: How to paint new organisol over old organisol #71803
06/13/08 12:25 PM
06/13/08 12:25 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
What is the reason for doing it? I have saved original organsol that was in not too bad shape. PM me if interested.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
