Re: Be Cool Radiator Hose length..please help
[Re: PC-CHARGER]
#717803
06/07/10 10:27 AM
06/07/10 10:27 AM
Posts: 913 Lafayette, IN
challengerman71
super street
super street
Lafayette, IN
Have a look at the Dayco 70434 hose. I think that is the number I used for mine. It has to be trimmed to fit but it has the correct length and bends once you cut a fair portion of it off. I'll check this evening to make sure that is the right number.
Is that an interchangable number for like napa, etc? Would that hose clear under a shaker base? Thanks for the help. Let me know for sure on the number when you get a chance
[Re: PC-CHARGER]
#717805
06/07/10 11:02 AM
06/07/10 11:02 AM
challengerman71
super street
super street
Lafayette, IN
Mine does not have a shaker so can't say for sure it will clear but I would think that it cold be trimmed shorter at the thermostat housing to lower it to clear. I'll get the number tonight and take a picture at the same time. NAPA should be able to cross the Dayco number. Just be aware that the hose has another bend and an additional 12-14" of length so when you initially see it, it looks totally wrong but once you cut it down, it works fine.
do you knwo what the over all length was? I cant seem to find that hose anywhere, it comes back as power steering hose.
[Re: challenger70]
#717812
06/08/10 06:10 PM
06/08/10 06:10 PM
challengerman71
super street
super street
Lafayette, IN
Do you have the 1,000hp setup, where the tank sits on the inner fender? I can get you some gates #'s tonight when I get home if so.
no just a standard be cool bought a few years ago. I found the hose that will work. Thanks though.
