Re: 4 Speed Clutch Pedal Return Question
[Re: BeBeep]
#717773
06/06/10 04:59 PM
06/06/10 04:59 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Thats a hacked setup.Where is the big over center spring?Unless you run a diaphram clutch you need it.Only springs are the OC and a small one on the fork.Rocky
Chrysler Firepower
[Re: therocks]
#717774
06/06/10 05:07 PM
06/06/10 05:07 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
I agree. The OC spring is on the other side of the clutch pedal arm. You can kinda see it in the pic but just barely. The fork spring is also installed.
Since the OC spring is there, any ideas?
[Re: therocks]
#717775
06/06/10 05:11 PM
06/06/10 05:11 PM
therocks
Niles , Ohio
What clutch are you running.A B&G or a diaphram?Are the nylon sleeves in the cross tube installed and greased properly?Rocky
Chrysler Firepower
[Re: BeBeep]
#717780
06/06/10 06:47 PM
06/06/10 06:47 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you say "it does not return" do you mean return from the floor? If so, this is common with some diaphram clutches and you'll have to remove the overcenter spring.
If you mean it comes back up but doesn't return to the up stop you need to adjust the fork pushrod free play to 5/32" at the fork and let the pedal free play take care of itself.
[Re: John_Kunkel]
#717781
06/06/10 07:56 PM
06/06/10 07:56 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
The pedal will push to the floor but will not return from the floor, I have to pull it back up to be able to depress it again.
So I may need to remove the OC spring eh?
[Re: SomeCarGuy]
#717782
06/06/10 07:58 PM
06/06/10 07:58 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
How much free play do you have?
I need to check. I am out of town right now so that will be next weekend.
[Re: Stanton]
#717784
06/06/10 10:53 PM
06/06/10 10:53 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
ANY clutch will push the pedal back up. So there is an adjustment/installation problem. My guess goes with your own thought ... that you haven't adjusted the rod properly, although I can't understand how you could miss that on installation. Get rid of the O/C spring with that clutch.
I appreciate the info and I will check it out. The last time I did anything install on a 4 speed car was about 25 years ago so I am definitely far from even a novice.
[Re: cudaboone]
#717786
06/06/10 11:02 PM
06/06/10 11:02 PM
Posts: 442 NRH, TX
BeBeep
super street
super street
NRH, TX
Had same thing happen when i installed centerforce clutch. Remove that big OC spring and you won't have anymore problems. Be careful removing that big azz spring. You will still need a little spring to bring the pedal full back.
Thank you. It seems like the guy I bought it from had the same problem as I did.
Thank you to everyone who responded.
