A-Body K-Frame question #717262
06/05/10 10:42 PM
06/05/10 10:42 PM
Poplar Bluff, Missouri
partfiler69 Offline OP
Still Wondering
Still Wondering
I read that a 68 A-Body K-Frame is the same for /6 and V8 applications. Does anybody know if there is any truth to this?
Back from hiatus
Re: A-Body K-Frame question [Re: partfiler69] #717263
06/05/10 11:12 PM
06/05/10 11:12 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Incorrect. They are different 67 and up.
BUT IIRC, the 64?-66 A-body ones are the same. But different motor mount brackets.
Re: A-Body K-Frame question [Re: autoxcuda] #717264
06/05/10 11:52 PM
06/05/10 11:52 PM
Still Wondering
Still Wondering
Thanks for the info. Probably never gonna pull the slant, Just wondering how limited I am as far as engine choices.
Back from hiatus
Re: A-Body K-Frame question [Re: partfiler69] #717265
06/06/10 12:22 AM
06/06/10 12:22 AM
So Cal
So Cal
Schumacher makes conversion mounts to use you /6 to mate to a small block.
And I think /6 to big block mount too?
Re: A-Body K-Frame question [Re: autoxcuda] #717266
06/06/10 12:24 AM
06/06/10 12:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yep, Schumacher has all the mounts, but that isn't the only way to go........
Re: A-Body K-Frame question [Re: Jim_Lusk] #717267
06/06/10 12:34 AM
06/06/10 12:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , it is possible to mount a smallblock on a /6 K , one side is the same mount smallblock and the slanty , the other side you use a V8 truck engine bracket .
Re: A-Body K-Frame question [Re: JohnRR] #717268
06/06/10 10:46 PM
06/06/10 10:46 PM
Still Wondering
Still Wondering
How is that done? Does the truck mount go on the drivers side, and will everything else line up?
Back from hiatus
Re: A-Body K-Frame question [Re: partfiler69] #717269
06/08/10 02:13 PM
06/08/10 02:13 PM
Still Wondering
Still Wondering
Back from hiatus
