727 Shifts Late #717199
06/05/10 09:23 PM
06/05/10 09:23 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
I know it has been asked a million times and believe me, I did check the archives and search. I just can't find it.
I have a 383/727 with a 2.76 rear.
I have the Bouchillon cable and their carb bracket.
My car shifts:
1-2 @ 25mph
2-3 @ 40+mph
Which way do I move the bracket that holds the throttle pressure cable? Towards or away from the carb?
Scott
1969 Super Bee, 383/4 speed
Re: 727 Shifts Late [Re: StukaJU87] #717200
06/05/10 09:27 PM
06/05/10 09:27 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if i remember correctly the the lever on the trans farther towards the front of the car the later the shift.
perception is 90% of reality
Re: 727 Shifts Late [Re: Mr T2U] #717201
06/05/10 11:49 PM
06/05/10 11:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kickdown length too long = late shift, quicker kickdown.
Kickdown length too short = early shift, reluctant to kick down (and hard on trans).
Slotted lever should rest against shaft with throttle closed, held fairly tight by spring. That's approximate, can be fine-tuned from there.
Re: 727 Shifts Late [Re: topside] #717202
06/06/10 04:15 PM
06/06/10 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OP has a Bouchillon cable, not stock linkage.
The further back the trans lever is at any throttle setting the later it will shift, you want to adjust the cable so the trans lever is further forward.
Re: 727 Shifts Late [Re: John_Kunkel] #717203
06/06/10 04:23 PM
06/06/10 04:23 PM
Northern NJ
Northern NJ
Thank you John. I appreciate that. I may have it just a tiny bit too tight. What should I try, like 1/8th inch looser?
Scott
Re: 727 Shifts Late [Re: StukaJU87] #717204
06/06/10 04:49 PM
06/06/10 04:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Loosen it up a little at a time until you are happy with the shift points.
