DOMINATOR JETTING ON MY 448" ??? #715655
06/03/10 11:32 PM
06/03/10 11:32 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
After trying out Mike's(Mr. P-Body)1050 dommy on my .040 over 440 last sunday at the strip,I was wondering where you guys jetted, running a modified 440,and 1050 carb? It is currently jetted at 88 square. Mike had installed 84's,thinking the 88's would be too rich! After checking the plugs,the jetting was too lean,in my opinion! Also...MPH dropped by 2-4 from the 850 holley! Any input would be appreciated! RandyB
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715656
06/03/10 11:37 PM
06/03/10 11:37 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
On my old 65 with the 11.1.1 440 at the time. with a box stock 8896 Holley 1050. If i remember right Dewayne had me set it up with 92 jets with pv in the front and no pv with 98 jets in the back.I ran 10.56 @ 125 set up that way.that carb does look awesome on your car. Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715657
06/03/10 11:37 PM
06/03/10 11:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Start it out at 88s Randy but have jets to jet up
88s were in it standard... we're going out Saturday
if you want to come... opens at noon
Re: DOMINATOR JETTING ON MY 448" ??? [Re: MR_P_BODY] #715658
06/03/10 11:48 PM
06/03/10 11:48 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Bobby! Mike,I put the 88's back in earlier this evening,but haven't changed the slicks back to the street tires as of yet! I don't dare drive that car on Belle River Rd. with slicks,I'll end up in a ditch,or one of the many corn fields around here! As far as saturday goes,sounds like a lot of yard work to catch up on,according to the "BOSS"! She's usually right,even though I hate to admit it! Let me(US)know how everything goes with you and Doug at the track! Best of Luck!
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715659
06/04/10 12:12 AM
06/04/10 12:12 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
90-92s on my 440 with a 1050
and 38* timing too
1.39 9.85 - 137 mph
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Ari440] #715660
06/04/10 12:40 AM
06/04/10 12:40 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Ari! How modified is your 440? Any idea how much hp and tq it makes?
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715661
06/04/10 12:51 AM
06/04/10 12:51 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Labratt, What fuel are you using in your car? I usually run 92's square jetted in my 8896 dominator on my 408 smallblock. However, i'm running pump gas, which i use more of than race gas, because of the lower octane rating.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715662
06/04/10 12:53 AM
06/04/10 12:53 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
446 ci
12.5 comp
613/276 u/d cam
stage 4 ported heads
M1 adapter 1050
10.85 123 mph
car weigths 3470 with me in it
I have a 511 indy sr,m/w motor in my car now
1.39 9.85 - 137 mph
Re: DOMINATOR JETTING ON MY 448" ??? [Re: 340_Dart] #715663
06/04/10 01:28 AM
06/04/10 01:28 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Andy,I run 100% premium unleaded from the pump. Stock Eddy Performers,only 10:25:1 compression! Timing's set at 39* total.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715664
06/04/10 01:39 AM
06/04/10 01:39 AM
Is this carb. a stock Holley? If so what is the list number on it and the dash number if it is a HP Domininator? I have found that starting with the stock jetting and going from there is best when you don't know which way to go on a second hand or borrowed carb. If it is a custom carb. start testing and jet up until it slows downs
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Cab_Burge] #715665
06/04/10 01:58 AM
06/04/10 01:58 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Cab,I'll have to get the numbers off of it tomorrow. As far as I know it's a factory,un-modified non-HP model. It belongs to Mr. P-Body! While we're on the carb subject, have you guys ever seen anyone run square jetting,with a PV in the primary???
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Cab_Burge] #715666
06/04/10 07:25 AM
06/04/10 07:25 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
X2 etc...FWIW I've wound-up with 92's sq. max (in good air) with the old 8896 and somewhat similair combo's.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: HardcoreB] #715667
06/04/10 07:28 AM
06/04/10 07:28 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I just looked at the first pic in this post...If that's the carb it is a 'new' model Dominator. As has been said I'd reference the designed/engineered fuel metering and move from there.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: HardcoreB] #715668
06/04/10 10:18 AM
06/04/10 10:18 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Sean! That's all I know is Mike said it came with 88 jets,out of the box. So...I'll start from there next time out to the track,probably in 2 weeks. Almost certain the Gratiot Cruise is next Saturday! QUESTION!...ended up with 82squared on the jetting with a pri. PV,on the 850 when it was on Jake's dyno a few weeks ago. Has anyone ever seen or heard of squared jetting with a PV??? Engine responds well,makes good power,but I've NEVER seen squared jetting using a power valve! BTW... A/F ratio was 13:2 with this combo. When I brought it in,I had the jetting set at 82/90 with a 4.5" pri. PV,and the A/F was 12:9. Temps were 83-85* and humidity was 41-43%! What do you guys think? RandyB
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715669
06/04/10 01:05 PM
06/04/10 01:05 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I ran 88's front and 92's rear, no power valve in bad air here in Las Vegas. I had a 446 11:1 and the 8896 carb.
Re: DOMINATOR JETTING ON MY 448" ??? [Re: moparmanjames] #715670
06/04/10 01:22 PM
06/04/10 01:22 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Just got the # off the dominator. It's a 8896 w/4-corner idle! BTW...what # dominator is generally considered to be the best for street/strip??? THANKS!
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715671
06/04/10 02:33 PM
06/04/10 02:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The one that gives you the best et of course. I run the 1050 8082-3 2-circuit and I love it................
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Thumperdart] #715672
06/04/10 05:37 PM
06/04/10 05:37 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Sounds like you might need to work on hooking that puppy up,,,was blowing the tires off big time once you nailed it.
Clamp the front section of the leaf springs ?? hmmmm
PS,,,i found another labrat guy,,,and put some "thoughts" with him,,,lol
Re: DOMINATOR JETTING ON MY 448" ??? [Re: 69CHARGERMD] #715673
06/04/10 09:52 PM
06/04/10 09:52 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for another LabRat,at least it's not a LabBat,like the last one!! Good news! Just got a good deal on some brand new Goodyear bias-ply 29"x9" D-3 slicks! Should be getting them early next week. Brian Harlow got me a good price on the tires,and the shipping! Should make a difference coming off the line! Doug is right,when I hit it off the line with the Dominator on,it just blew the tires off! Spun for the first 40-60 ft.! BIG increase in low-end torque,and under lean conditions!
Re: DOMINATOR JETTING ON MY 448" ??? [Re: Labratt] #715674
06/05/10 07:10 AM
06/05/10 07:10 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Still waiting for an answer on my square-jetted using a power valve question! ANYONE EVER SEE OR HEAR OF THIS BEING DONE??? Thanks! RandyB
