Do I need a PCV Valve and Breather? #714333
06/02/10 05:02 PM
06/02/10 05:02 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
What exactly do each do and do I need a PCV Valve? Any Advantages to having a pcv valve? This would be for a 60's era 440. A rookie question I know but I never knew for sure.
Re: Do I need a PCV Valve and Breather? [Re: challenger70] #714334
06/02/10 05:12 PM
06/02/10 05:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The breather allows air in one side of the engine and the PCV pulls the fumes and pressure out of the crankcase and runs them back through the engine to be burnt. Without the breather you wouldn't have the necessary crossflow. Without the two of them working together you would build up pressure in the crankcase which results in oil getting blown out of all the seals. Using a breather in each valve cover will result in oil being blown out of them and all over the engine.
Re: Do I need a PCV Valve and Breather? [Re: stumpy] #714335
06/02/10 05:40 PM
06/02/10 05:40 PM
Berwyn, IL
Berwyn, IL
Cool, thanks for the great explanation, I wasn't sure if the PVC was related to some emmissions stuff I don't need.
Re: Do I need a PCV Valve and Breather? [Re: challenger70] #714336
06/02/10 05:46 PM
06/02/10 05:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The pcv DOES keep the oil aroma down while at stoplights, etc.
Re: Do I need a PCV Valve and Breather? [Re: challenger70] #714337
06/02/10 08:06 PM
06/02/10 08:06 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
It was one of the first and it was a good thing that we have them because before that there was only a draft tube.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Do I need a PCV Valve and Breather? [Re: HealthServices] #714338
06/02/10 08:12 PM
06/02/10 08:12 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Yes. Good.
Positive Crankcase Ventilation is a much more complete way to remove water vapor and other undesirables*, when compared to a passive system.
*Disclaimer: Does not work well for removing visiting in-laws who have over-stayed their welcome.
Down to just a blue car now.
Re: Do I need a PCV Valve and Breather? [Re: 68HemiB] #714339
06/02/10 09:50 PM
06/02/10 09:50 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Yes. Good.
This really was a great innovation. The roads are actually clearer of oil, especially in the center. That was typically where the "draft" or "blow-by" dumped the gunk that pvc system collects. Its still bad but in early years, the center of the road was the worst place for a motorcyclist to be when it started raining. Can you say, "Slip'n'Slide"??
Re: Do I need a PCV Valve and Breather? [Re: Scott Carl] #714340
06/02/10 10:20 PM
06/02/10 10:20 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Any advantage to having the PCV on one side or the other? I notice the factory changed sides around 70.
So I gather that the drivers side must have had an advantage.
I want my fair share
Re: Do I need a PCV Valve and Breather? [Re: SomeCarGuy] #714341
06/02/10 10:23 PM
06/02/10 10:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Probably cheaper and more room. No a/c or heater hoses to deal with. There is no real reason to favor the driverside.
Re: Do I need a PCV Valve and Breather? [Re: stumpy] #714342
06/02/10 10:34 PM
06/02/10 10:34 PM
IN
ahy Offline
ahy  Offline
IN
The spinning crank will throw more oil on one side at high RPM. Its best to have the breather on the opposite side to reduce the possibility of sucking oil. I think this favors (slightly) putting the PCV on the pass side.
