Re: Do I need a PCV Valve and Breather?
[Re: 68HemiB]
#714339
06/02/10 09:50 PM
06/02/10 09:50 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Cool, thanks for the great explanation, I wasn't sure if the PVC was related to some emmissions stuff I don't need.
It was one of the first and it was a good thing that we have them because before that there was only a draft tube.
Yes. Good.
Positive Crankcase Ventilation is a much more complete way to remove water vapor and other undesirables*, when compared to a passive system.
*Disclaimer: Does not work well for removing visiting in-laws who have over-stayed their welcome.
This really was a great innovation. The roads are actually clearer of oil, especially in the center. That was typically where the "draft" or "blow-by" dumped the gunk that pvc system collects. Its still bad but in early years, the center of the road was the worst place for a motorcyclist to be when it started raining. Can you say, "Slip'n'Slide"??
[Re: Scott Carl]
#714340
06/02/10 10:20 PM
06/02/10 10:20 PM
Posts: 10,233 Someplace you aren't
SomeCarGuy
Any advantage to having the PCV on one side or the other? I notice the factory changed sides around 70.
So I gather that the drivers side must have had an advantage.
I want my fair share
[Re: stumpy]
#714342
06/02/10 10:34 PM
06/02/10 10:34 PM
Posts: 7,664 IN
ahy
IN
The spinning crank will throw more oil on one side at high RPM. Its best to have the breather on the opposite side to reduce the possibility of sucking oil. I think this favors (slightly) putting the PCV on the pass side.
