440 rotating assembly #714289
06/02/10 04:25 PM
06/02/10 04:25 PM
Modesto, CA
Chris_Holton Offline OP
Modesto, CA
who has the best deals (non stroker kits) I am building a bracket race engine and need a nice rotating kit to purchase...thanks, for any help...c.h....
Re: 440 rotating assembly [Re: Chris_Holton] #714290
06/02/10 09:18 PM
06/02/10 09:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If your buying a rotating assembly why would you not go stroker it's the same money??
Re: 440 rotating assembly [Re: Dodgem] #714291
06/02/10 10:09 PM
06/02/10 10:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yeah, really !!!!!!!
Re: 440 rotating assembly [Re: Stanton] #714292
06/03/10 12:06 AM
06/03/10 12:06 AM
Modesto, CA
Modesto, CA
The guy has me pinned to a budget, lose the job or give the man what he asked for. I agree, the stroker is the way to go, a little extra work on the block but worth it...
Re: 440 rotating assembly [Re: Chris_Holton] #714293
06/03/10 08:33 AM
06/03/10 08:33 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What work on the block?? 5 minutes of grinding on most kits and the 2.20 rod kits need nothing till 520" or so!!!
Don't think anyone sells a stock stroke kit??
maybe best to just find a more competent machinist he don't know nothing bout them strokers you speak of so he wants to stay in his comfort zone!
Check out
440 source
Mancini
Muscle motors
Koffels
Now if you have your stock crank maybe use it with a rebuild kit
Re: 440 rotating assembly [Re: Dodgem] #714294
06/03/10 09:39 AM
06/03/10 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check out
440 source
Mancini
Muscle motors
Koffels
I don't see why there isn't a stock stroke kit , think ouside the CCJ box
Re: 440 rotating assembly [Re: JohnRR] #714295
06/03/10 09:44 AM
06/03/10 09:44 AM
tboomer Offline
tboomer  Offline
Call Muscle Motors...I bought my 512 kit from them. I am sure they have a stock kit,too...Mike and Eric were great to deal with!!
Re: 440 rotating assembly [Re: Dodgem] #714296
06/03/10 09:49 AM
06/03/10 09:49 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Check out
440 source
Mancini
Muscle motors
Koffels
Sounds to me like the OP IS The machine shop, and he's trying to provide what the customer wants. Maybe all the customer brought in was a bare block and there is no stock rotating assembly to work with?
anyway, to answer the original question, I'm sure someone is making stock stroke cranks, for various classes of racing where the rules dictate that a stock stroke be used...they just don't openly advertise it because so few people want to spend the same money as a stroker kit, for a stock stroke.
if there isn't anyone making one, then hit the classifieds for a deal on used stuff, even if it needs re-worked. going with a used factory crank that's been re-worked is probably cheaper than buying a new forged crank anyway, especially when comparing stock stroke to stock stroke.
**Photobucket sucks**
Re: 440 rotating assembly [Re: Chris_Holton] #714297
06/03/10 09:52 AM
06/03/10 09:52 AM
AndyF Offline
AndyF  Offline
Mancini Racing, Hughes Engines, Bob Mazzolini Racing, IMM, Muscle Motors, etc. can all get you the parts you need.
Or try to find a guy named Harry Holton in Modesto. He is really sharp with engines. I'm sure Harry could tell you how to buy parts for a Chrysler.
Re: 440 rotating assembly [Re: AndyF] #714298
06/03/10 10:38 AM
06/03/10 10:38 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Hmmm...Chris Holton from Modesto CA is asking about engines, who also says he's a 3rd generation mechanic in his profile...could he be related to Harry? if so, why the "elementary question" when such an expert is in the family?
Re: 440 rotating assembly [Re: 70Cuda383] #714299
06/03/10 10:48 AM
06/03/10 10:48 AM
Modesto, CA
Modesto, CA
My customer wants a 440, not a stroker. I am porting the 915 heads as requested, the core short block has a cast crank so I am starting from scratch.anybody can add cubic inches, aftermarket heads and run fine, I enjoy beating them with orignal looking stuff.....
Re: 440 rotating assembly [Re: Chris_Holton] #714300
06/03/10 12:01 PM
06/03/10 12:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would use the cast crank with 915 heads you not going to make 700 hp and cast are good to 600 +.
with lightweight pistons and aftermarket H beam rods will internally balance up nice.
or polish the stock rods resize with new ARP bolts.
What about a stroker kit makes it look non stock????
Or are you putting giant windows in the side of the block to look in?????
If I was your customer and I found out you charged me X for a 446 cubic inch and for the same money maybe less I could have had 512 I don't think I would be happy!
Re: 440 rotating assembly [Re: Dodgem] #714301
06/03/10 12:12 PM
06/03/10 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what's your point ??
Why is it that people just can't answer a freakin' question , the guys wants info on a STOCK STROKE KIT , who gives a rats backside what anyones else opinion is on how SOMEONE ELSE should spend THEIR OWN money .
I'm with Chris , I love it when someone with a smaller engine kicks the crap out of the BLOWHARD with the blah blah blah stroker this ...
Re: 440 rotating assembly [Re: JohnRR] #714302
06/03/10 12:26 PM
06/03/10 12:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I did answer his question say to use the crank he has in two differnt posts.
The rest were my questions??
cranks new (he did not ask for a used forged to build around)
http://chucker54.stores.yahoo.net/crankshafts1.html
then a kit
http://chucker54.stores.yahoo.net/sealpowkitd1.html
and I would suggest
http://chucker54.stores.yahoo.net/corodse1.html
My question is why not already balanced.
A.
http://chucker54.stores.yahoo.net/inba.html
B.
http://www.440source.com/strokerkits.htm
C. and see a 440/440 kit but does stock crank mean a cast??
http://www.musclemotorsracing.com/stroker-category/440-stroker-kit-article
Re: 440 rotating assembly [Re: JohnRR] #714303
06/03/10 12:26 PM
06/03/10 12:26 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Hey, check out the top item on this page, this looks good.
