HEMI ROLLER CAM SPECS HELP #714086
06/02/10 01:29 PM
06/02/10 01:29 PM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
HELLO
I HAVE A ROLLER CAM HERE THAT I WAS HOPING YOU MAYBE ABLE TO HELP WITH THE SPECS
I DONT KNOW THE MANUFACTORER
ITS OUT OF A 426 HEMI
ON THE FRONT OF THE CAM IS SCRIBED:
286-1
295-5
R6
E
933256 (MAY BE 433256)
ON THE REAR OF THE CAM IS STAMPED:
669476
92F1B
IF YOU COULD HELP ME WITH THE SPECS ID REALLY APPRECIATE IT
THANKS
TONY
Re: HEMI ROLLER CAM SPECS HELP [Re: TONY_DAGOSTINO] #714087
06/02/10 07:00 PM
06/02/10 07:00 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The grind number (669476) looks like a Crane number. I couldn't find that number. It looks like the durations are 285@.050" intake and 295 exhaust. The question is the LSA, is it 106 or 116? If it is 116, then it's probably a blown alcohol cam.
Floyd Lippencott IV
Re: HEMI ROLLER CAM SPECS HELP [Re: mr_340] #714088
06/03/10 07:44 AM
06/03/10 07:44 AM
DELAWARE
DELAWARE
hi,
thanks for the help
its was running in a street hemi engine, not saying that it couldnt have been in a blown alky motor prior, but it doesnt have much if any wear
any ideas on what the lift would be?
thank you
tony
Re: HEMI ROLLER CAM SPECS HELP [Re: TONY_DAGOSTINO] #714089
06/03/10 12:10 PM
06/03/10 12:10 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Comp Cams has a baseline SS cam with similar specs. See the attached PDF. I'd guess around .750"-.800" lift. You should be able to get a rough idea by measuring the lobes with a caliper. It won't be perfect, but probably within 10-20%.
6018572-CCHemiCams.pdf (207 downloads)
Floyd Lippencott IV
