Camshaft Identification #714082
06/02/10 01:27 PM
06/02/10 01:27 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Anyone seen a cam shaft with these painted dots on it? it has 1136 cast in and 537600 stamped next to the dots? Out of a 340
6016711-Engine039.pdf (339 downloads)
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Camshaft Identification [Re: 19cuda73] #714083
02/14/11 07:24 PM
02/14/11 07:24 PM
East Coast
Blue Dodge Bob Offline
East Coast
I'm trying to identify a cam that came out of my 440.
It has a couple of tan dots on it with the number 894440. The shaft of the cam bears the letters "CWC" and the numbers 1104 ( they are cast into it).
Did anyone ID your cam?
Any idea what brand mine is and what the specs are for it?
Re: Camshaft Identification [Re: Blue Dodge Bob] #714084
02/14/11 09:14 PM
02/14/11 09:14 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
To both of you guys those 4 digit numbers indicate after market cores not used specifically by mopars. Ive seen 1117 , 1103 and now your numbers. Ive seen eldebrock cams with 1103
But what is more specific to mopar is the 6 digit numbers. Independit of themselves, I dont know if they can be cross refrenced to a MP cam specific number. The two dots implies its a MP cam also.
The Quickest and easiest way to tell witch MP cam you have is to mike and compare the lobes base circle to its max lift diameter and multiply it by 1.5 With the MP cams there is enough lift difference between the cams to figure out what you have.
When Ive measured them that way, I get within .02 or Better. And thats Mostly because of the Cams loose tolerences.
Example, I just measured a MP cam laying around.
Measuring things Twice I got 1.2425/1.2430 for the base circle, and 1.5645/1.5650 for max lobe.
If I subtract the furthest numbers apart 1.5650 max lobe - 1.2425 base circle = .323
mutiply that by 1.5 RR = .4845 lift.
That cam can only be the MP 484. If you figure the lift you will pretty surely know witch cam you have.
Re: Camshaft Identification [Re: Sport440] #714085
02/15/11 11:43 AM
02/15/11 11:43 AM
East Coast
East Coast
Thanks,
My cam is apparently the "440 Six Pack" cam! The two different lifts threw me off for a second. Very good cam.
Very good information. I wonder if the color of the dots wouldn't indicate the ID of each cam ?
