Eastwood's fastrax aligment tool #713378
06/01/10 04:46 PM
06/01/10 04:46 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
has anyone used it?
I have a few questions
1/ whats a ball park figure to adjust the camber?
2/ how to do you adjust the caster?
3/ a little toe in? is this preferred ?
Re: Eastwood's fastrax aligment tool [Re: AK_JH27] #713379
06/01/10 05:37 PM
06/01/10 05:37 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
My
Most people agree anywhere from 0 to 1/2 negative camber.
Change it by moving the upper ball joint in relation to the lower ball joint.
With most early mopars you adjust the upper eccentric adjustment at the upper control arm.
Almost always 'in' not 'out'
Most your wear will be from toe and toe change when braking. Toe will tend to want to toe out during braking.
Re: Eastwood's fastrax aligment tool [Re: HealthServices] #713380
06/01/10 05:52 PM
06/01/10 05:52 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
AS posted here MANY times. SEt the ride height FIRST. I don't like the factory way so I suually set about an inch between the lower control arm frame bumper and the frame. Then I use the LCA body and frame distance and set both sides the same.
Then set the adjusting cams with the front all the way out and the rear all the way in. Adjust the rear cam out until you have the desired 1/2 degree negative camber. Do this on both sides and check caster, but this the MOST positive caster you will get with the current set of parts on the car.
Now, set the tow to about 1/16-1/8" IN.
Re: Eastwood's fastrax aligment tool [Re: Jim_Lusk] #713381
06/01/10 06:08 PM
06/01/10 06:08 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
John
not following you on the adjusting cam, for the front all the way out? rear all the way in? sorry not getting it.
Re: Eastwood's fastrax aligment tool [Re: AK_JH27] #713382
06/01/10 06:23 PM
06/01/10 06:23 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
When you look at the cams it should be clear.....
Re: Eastwood's fastrax aligment tool [Re: AK_JH27] #713383
06/01/10 06:40 PM
06/01/10 06:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I have used that tool with great sucess.
Start with the front cam all the way out, and the rear all the way in.
Jim Lusk is dead on.
Re: Eastwood's fastrax aligment tool [Re: AK_JH27] #713384
06/02/10 08:22 AM
06/02/10 08:22 AM
Maryland
mrob Offline
mrob  Offline
Maryland
I used one to align my Cuda after I rebuilt the front suspension. Jim Lusk describes the steps correctly, but let me add something else. To do it right, you need to use wheel alignment turn plates so that you can smoothly turn the wheel back and forth for the caster measurement. Some people make their own turn plates, but I bought a pair of cheapie plates form Harbor Freight. The turn plates also help the suspension settle. Another thing - make sure that you have the car leveled on the turn plates (more important for camber measurement).
Re: Eastwood's fastrax aligment tool [Re: AK_JH27] #713385
06/02/10 09:32 AM
06/02/10 09:32 AM
Cincinnati, Ohio
Cincinnati, Ohio
Made my own turn plates from 4 peices of 14ga steel with grease in between them. They sit flat on the floor making it easy to get the car on them. It also alllows the car to sit level front to rear. I bought my alinement tool from Summit Racing.
Re: Eastwood's fastrax aligment tool [Re: Challenger 1] #713386
06/02/10 10:15 AM
06/02/10 10:15 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Made my own turn plates from 4 peices of 14ga steel with grease in between then. They sit flat on the floor making it easy to get the car on them. It also alllows the car to sit level front to rear. I bought mine from Summit Racing.
This is a great thread!! Maybe save for the tech archives? I have also read somewhere (maybe here??) someone using vinyl tile squares with grease between them. Smaller targets, I suppose, but use what ya got, I say
Re: Eastwood's fastrax aligment tool [Re: Challenger 1] #713387
06/02/10 11:17 AM
06/02/10 11:17 AM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
thats a really good idea
thanks
