odd ball question of the day. #713011
06/01/10 09:40 AM
06/01/10 09:40 AM
jamestown, ny
71scamp440 Offline OP
Hinged
Hinged
jamestown, ny
my boss has a 73 duster that he drag races . has a 400 block stroked to a 472. its an alcohol motor. now the problem he is having is new to me . after 3 1/8th mile passes the intake valley pan split down the middle. its about a 7in crack right down the center . this is one of the most bizzare thing ive ever ran into. any ideas on this one???
71 scamp big block with 915 heads 727 trans
Re: odd ball question of the day. [Re: 71scamp440] #713012
06/01/10 11:23 AM
06/01/10 11:23 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've had a few of them split on me too. It's caused by pressure inside the crank case. The pan flexes up and down until it fatigues and splits along one of the creases.
You're probably getting a lot of blow by or don't have the engine properly vented.
- Stu Harmon
Re: odd ball question of the day. [Re: 71scamp440] #713013
06/01/10 11:27 AM
06/01/10 11:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty simple really... he is pressurizing the engine
with blow by... the crank case is building pressure
from the air passing the rings... put a gauge on
a valve cover to measure the pressure... a vac pump
will eliminate/correct the problem
Re: odd ball question of the day. [Re: 71scamp440] #713014
06/01/10 11:55 AM
06/01/10 11:55 AM
jamestown, ny
Hinged
Hinged
jamestown, ny
i guess this is more common then i thought. thanks for the info guys. i will pass on your info on to my boss and hopefully he will be able to run a full day with out covering his windshield with oil.
Re: odd ball question of the day. [Re: 71scamp440] #713015
06/01/10 12:33 PM
06/01/10 12:33 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
My brothers old hi comp. 440 would do that. We put the header evac on it and it quit
