Re: Magnum Head gaskets
[Re: snojet]
#711801
05/30/10 11:23 PM
05/30/10 11:23 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Victor-Reinz is what they were build with.Graphite coated.They were the best by far in all the testing on the Magnum engines.
Leave the gun.......take the Cannoli's....Mike
[Re: snojet]
#711802
05/31/10 07:58 AM
05/31/10 07:58 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
Which port to the valley, I have heard of the intakes not sealing correctly to the head causing leaks into the valley but never the heads themselves leaking unless using cometic gaskets.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: gdonovan]
#711804
05/31/10 08:17 AM
05/31/10 08:17 AM
Posts: 2,826 NY usa
540challenger
NY usa
I would mock up with no intake gaskets to make sure everything is where it should be. There is no reason to have a leak with the Fel-pro gasket, it is a fine choice.
x2 Also when using aftermarlet heads i would double check to make sure the dowl pins aren't holding the head up. good luck
[Re: snojet]
#711806
05/31/10 10:21 AM
05/31/10 10:21 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
It is NOT the head gasket causing the problem. Has to be a crack or the water port is not in the right position in the head or dowls are holding the head up a little or the bolts are a little too long or mabey the head gasket was bent or something but I have built a lot of motors with those gaskets and magnum heads and never had one leak.
[Re: snojet]
#711812
06/05/10 08:23 AM
06/05/10 08:23 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
They feel that nobody has made a high perf. head gasket for the 5.9 Mag.
Wow what a statment for them to make.
Only have one word to say, Cometic.
Yes, Cometic does make Magnum headgaskets.
[Re: snojet]
#711813
06/05/10 10:39 AM
06/05/10 10:39 AM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Felpro 1008'S (for LA motors) are a proven head gasket for 5.2 and 5.9 magnum motors too.
Dakota for life!
