Dumb question, if 440 dist is 180 out how to fix? ASAP #711724
05/30/10 07:23 PM
05/30/10 07:23 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I'm trying to start my 512 and I think the dist is 180 out. It cranks good, but backfires (loudly). How do I fix it, pull it out and turn the bottom or switch the wires around on the cap?
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: NV69B7RR] #711725
05/30/10 07:35 PM
05/30/10 07:35 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Bring engine up to top dead center on #1
Remove dis. cap and make sure its pointing to #1 plug.
If its 180 out unbolt dis pull dis and turn rotor 180 and tighten down.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: NV69B7RR] #711726
05/30/10 07:36 PM
05/30/10 07:36 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Lift it about an inch,turn rotor half turn.If you're out,you're in.Easier than changing wires and correct.
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: 62maxwgn] #711727
05/30/10 08:35 PM
05/30/10 08:35 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks, I took it and turned it 180 and vavoom!
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: NV69B7RR] #711728
05/30/10 09:07 PM
05/30/10 09:07 PM
PA.
"Little"John
"Little"John
PA.
Good deal. Nothing better than hearing a new engine fire up. NOW GO HAVE SOME FUN.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: pittsburghracer] #711729
05/30/10 11:34 PM
05/30/10 11:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This reminded me of a good buddie of mine. He just rebuilt his 360 (89 TBI setup) and could not get it to fire, same symptoms you mentioned. I asked him if he was sure his timing wasn't 180 and he said no. After jumping thru many hoops I fnally moved his rotor 180 out and it fired right up. Normally, this guy is Mr. Attention to detail, but somehow he eissed that one up.
Don't be the exception.
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: Supercuda] #711730
05/31/10 10:05 AM
05/31/10 10:05 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think everybody w/ a BB mopar has done that at least twice. Glad you fixed it.
Coming soon!!!!
Re: Dumb question, if 440 dist is 180 out how to fix? ASAP [Re: Mr.Yuck] #711731
05/31/10 12:58 PM
05/31/10 12:58 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I had a 66 Valiant given to me one time for this reason. Owner got tired of trying to make it run...I pushed it on the trailer took it home and put the dist. in 180 and drove it for a year lol
