Re: Dumb question, if 440 dist is 180 out how to fix? ASAP
[Re: NV69B7RR]
#711725
05/30/10 07:35 PM
05/30/10 07:35 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Bring engine up to top dead center on #1 Remove dis. cap and make sure its pointing to #1 plug. If its 180 out unbolt dis pull dis and turn rotor 180 and tighten down.
[Re: pittsburghracer]
#711729
05/30/10 11:34 PM
05/30/10 11:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
This reminded me of a good buddie of mine. He just rebuilt his 360 (89 TBI setup) and could not get it to fire, same symptoms you mentioned. I asked him if he was sure his timing wasn't 180 and he said no. After jumping thru many hoops I fnally moved his rotor 180 out and it fired right up. Normally, this guy is Mr. Attention to detail, but somehow he eissed that one up.
