Transmission Issues- **FIXED**
#711410
05/30/10 12:25 PM
05/30/10 12:25 PM
Posts: 6,295 U.S.
moparniac
U.S.
Mopar Performance
Post deleted by Defbob
[Re: moparniac]
#711411
05/30/10 12:51 PM
05/30/10 12:51 PM
Re: Transmission Issues
#711412
05/30/10 01:01 PM
05/30/10 01:01 PM
Posts: 6,295 U.S.
moparniac
U.S.
when I slightly push the car it fells locked but a little more pressure it just seems to come out and then start making the clicking sound! A local shop built it ......
Mopar Performance
[Re: moparniac]
#711417
05/30/10 01:42 PM
05/30/10 01:42 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
are you using the same hard part's as before or is this a new tranny??
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: StripeHOG]
#711418
05/30/10 02:04 PM
05/30/10 02:04 PM
Posts: 6,295 U.S.
moparniac
U.S.
tranny was just rebuilt and has not been used yet.
Mopar Performance
[Re: moparniac]
#711419
05/30/10 02:08 PM
05/30/10 02:08 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
It might be a easy fix. The pan will need to come off of coarse. Then take a look at things. The valve body might need to be pulled and with this will out come the parking rod. You will see then how it works.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: turbocolt2.4L]
#711423
05/30/10 07:45 PM
05/30/10 07:45 PM
Posts: 6,295 U.S.
moparniac
U.S.
the VB just kinda fell out meaning the rod going into the tranny did....... i cant get it up past the slot door and im thinking the end piece circled is on backwards why it wont go in?
Mopar Performance
[Re: moparniac]
#711429
05/30/10 08:52 PM
05/30/10 08:52 PM
dartman366
Mt. Vernon, Ohio
there are two length rod's one for 904's (short) and one for 727's (long) is that the same VB that was in the trans before the rebuild? the rod will fit but sometime's they can be a pain, I always put a dab of grease on the end that slip's into the parking pawl, I have even had to take the extention housing off, installed the VB and then reinstalled the housing to get it to go together.
