Transmission Issues- **FIXED** #711410
05/30/10 12:25 PM
05/30/10 12:25 PM
U.S.
moparniac Offline OP
U.S.
well it seems I can roll the car around in park tried asjusting the cable and no help either!!!! even without the cable attached and I move the lever by hand to Park I can still roll the car and here the clicking
thoughts
Mopar Performance
Post deleted by Defbob [Re: moparniac] #711411
05/30/10 12:51 PM
05/30/10 12:51 PM
Re: Transmission Issues #711412
05/30/10 01:01 PM
05/30/10 01:01 PM
U.S.
U.S.
when I slightly push the car it fells locked but a little more pressure it just seems to come out and then start making the clicking sound!
A local shop built it ......
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711413
05/30/10 01:07 PM
05/30/10 01:07 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
what year trans?
Re: Transmission Issues [Re: dOoC] #711414
05/30/10 01:13 PM
05/30/10 01:13 PM
U.S.
U.S.
what year trans?
no idea on that one.... how do you check? or numbers at to check... thx
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711415
05/30/10 01:32 PM
05/30/10 01:32 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Push button trans ? ...two cables? ...or is this a single cable aftermarket shifter .... like B&M ? ...with a lever off the drivers side of the trans itself.
Re: Transmission Issues [Re: dOoC] #711416
05/30/10 01:40 PM
05/30/10 01:40 PM
U.S.
U.S.
B&M pro ratchet with single cable........ even without the cable installed and its moved the whole way into park it still jumps out and clicks...
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711417
05/30/10 01:42 PM
05/30/10 01:42 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
are you using the same hard part's as before or is this a new tranny??
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Transmission Issues [Re: StripeHOG] #711418
05/30/10 02:04 PM
05/30/10 02:04 PM
U.S.
U.S.
tranny was just rebuilt and has not been used yet.
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711419
05/30/10 02:08 PM
05/30/10 02:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It might be a easy fix. The pan will need to come off of coarse. Then take a look at things. The valve body might need to be pulled and with this will out come the parking rod. You will see then how it works.
Re: Transmission Issues [Re: Bob_Coomer] #711420
05/30/10 02:12 PM
05/30/10 02:12 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Sounds like the park-rod is messed-up.
Re: Transmission Issues [Re: dOoC] #711421
05/30/10 04:42 PM
05/30/10 04:42 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
It sounds like the park rod is damaged or in wrong. I had this happen once when I installed a new valve body. I fortunately tested the park before installing the pan.
I would pull the valve body and reinstall then put the shifter in park and try and turn the wheels on jack stands before even installing the pan.
Re: Transmission Issues [Re: DodgeCharger] #711422
05/30/10 07:39 PM
05/30/10 07:39 PM
CT
turbocolt2.4L Offline
CT
there are two style parking gears one has wider /deeper notches than the other i ran into this one time putting some parts i bought from a vender on this site but after i spoke to them they sent out the rite part see if shop changed the parking gear.
Re: Transmission Issues [Re: turbocolt2.4L] #711423
05/30/10 07:45 PM
05/30/10 07:45 PM
U.S.
U.S.
the VB just kinda fell out meaning the rod going into the tranny did....... i cant get it up past the slot door and im thinking the end piece circled is on backwards why it wont go in?
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711424
05/30/10 08:28 PM
05/30/10 08:28 PM
U.S.
U.S.
well after some research that end peice is on right. seems it was never engaged and is a pain in the xxx to get in there. any tips
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711425
05/30/10 08:29 PM
05/30/10 08:29 PM
Mohnton, Pa
Mohnton, Pa
Did you try turning the wheels and then try again to reinsert.
Re: Transmission Issues [Re: moparniac] #711426
05/30/10 08:31 PM
05/30/10 08:31 PM
Mohnton, Pa
Mohnton, Pa
It doesn't look backwords but I'm not an expert
Re: Transmission Issues [Re: DodgeCharger] #711427
05/30/10 08:31 PM
05/30/10 08:31 PM
U.S.
U.S.
yea no luck
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711428
05/30/10 08:32 PM
05/30/10 08:32 PM
U.S.
U.S.
i can reach up inside the tranny and slide it over with my finger but pushing the rod up there dont work!
Mopar Performance
Re: Transmission Issues [Re: moparniac] #711429
05/30/10 08:52 PM
05/30/10 08:52 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
there are two length rod's one for 904's (short) and one for 727's (long) is that the same VB that was in the trans before the rebuild? the rod will fit but sometime's they can be a pain, I always put a dab of grease on the end that slip's into the parking pawl, I have even had to take the extention housing off, installed the VB and then reinstalled the housing to get it to go together.
