91 Acclaim, wiper motor problems... #71059
06/10/08 08:23 PM
06/10/08 08:23 PM
Morningside
AdventurerSport Offline OP
waaaay out there in left field
Morningside
I'm stumped on this one guys, what do you think?
Wipers quit working, ok, fine. Test the motor, bad. Replace with NEW unit from NAPA. Worked for 2 days, now, not. So, I think I just got a bad one, fine, swapped it out for a warranty unit, it worked for all of 45 seconds and quit, now won't go. Power is at the plug, power goes on and off with the switch, as it should. ??
Am I just doing something wrong, or did I get 2 bad motors in the same week? Is there a relay or something screwing me up that I'm not seeing? Again, plug is hot with the test light. Comes on and off as it should...motor is not in a bind, just doesn't go.
Any ideas? Thanks!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 91 Acclaim, wiper motor problems... [Re: AdventurerSport] #71060
06/10/08 09:08 PM
06/10/08 09:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You are losing the ground. Run an auxillary small 16 ga ground from the armature field to the body. Reason it worked is because you wiggled the ground.
Re: 91 Acclaim, wiper motor problems... [Re: NITROUSN] #71061
06/10/08 09:09 PM
06/10/08 09:09 PM
Morningside
Morningside
I was thinking about that...:)
Thanks N, I'll try that and let ya know
JS
Re: 91 Acclaim, wiper motor problems... [Re: AdventurerSport] #71062
06/12/08 07:11 PM
06/12/08 07:11 PM
Morningside
Morningside
Tried to ground it, no luck...has plenty of ground, even bypassing the plug altogether and grounding it to the battery...:)
As best I can tell, I just got another bad motor...my luck...
JS
Re: 91 Acclaim, wiper motor problems... [Re: AdventurerSport] #71063
06/12/08 09:26 PM
06/12/08 09:26 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
On my old Dak, I tried 2 reman units and gave up. One lasted a month (in a bad rain storm), the other about 10 minutes. Got a new one from Mopar and worked perfect from then on. You get what you pay for.
Re: 91 Acclaim, wiper motor problems... [Re: njmopar] #71064
06/12/08 09:45 PM
06/12/08 09:45 PM
Beckley
cuda70 Offline
cuda70  Offline
Beckley
does it have a delay or 2 speed sometimes the delay goes bad.
Re: 91 Acclaim, wiper motor problems... [Re: njmopar] #71065
06/12/08 10:39 PM
06/12/08 10:39 PM
Morningside
Morningside
Oh, I agree..but these are NEW units from NAPA...not cheap junk by any means, not even the "economy" line from NAPA..?
Thanks for the reply!
JS
