Re: need NEON help
[Re: calimoparguy]
#709471
05/27/10 06:59 PM
05/27/10 06:59 PM
Posts: 684 Amherst , Ohio
1972cudaguy
Basement Office
Basement Office
Amherst , Ohio
look at neons.org there's a code section there somewhere . I've found lots of help there
Re: need NEON help
[Re: gtx6970]
#709473
05/27/10 07:47 PM
05/27/10 07:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Another possibility, happened on my 96 and my MIL's 98, is an EGR valve that is carboned up open.
Not sure if they fixed that issue by '01. Easy way to clean it is to dunk the mechanical part ONLY in MEK to soak and it'll clean out the carbon. DO NOT put the diagphram in the MEK or you will be buying a new one ($80+ last time I checked).
Steve
Re: need NEON help
[Re: Supercuda]
#709474
05/27/10 08:54 PM
05/27/10 08:54 PM
Posts: 10,644 S.E.Ohio
Magnumguy
S.E.Ohio
Easy way to clean it is to dunk the mechanical part ONLY in MEK to soak and it'll clean out the carbon. Steve
MEK?
Re: need NEON help
[Re: Magnumguy]
#709475
05/27/10 09:05 PM
05/27/10 09:05 PM
Supercuda
About to go away
About to go away
up yours
Methyl Ethyl Ketone
if you can get it, wear gloves, do it outside, don't breathe the fumes
