need NEON help #709469
05/27/10 05:21 PM
05/27/10 05:21 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
Wife has a 2001 neon.It starts but idle fluctuates up and down and trouble code 0508 came up....what the heck could be wrong
Re: need NEON help [Re: calimoparguy] #709470
05/27/10 05:55 PM
05/27/10 05:55 PM
so cal,cali
so cal,cali
do u think a hole in the rubber boot going from throttle body to motor??
Re: need NEON help [Re: calimoparguy] #709471
05/27/10 06:59 PM
05/27/10 06:59 PM
Amherst , Ohio
1972cudaguy Offline
Basement Office
1972cudaguy  Offline
Basement Office
Amherst , Ohio
look at neons.org there's a code section there somewhere . I've found lots of help there
Re: need NEON help [Re: calimoparguy] #709472
05/27/10 07:02 PM
05/27/10 07:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
DTC P0508 is; Idle Air Control Circuit Low. Which means the Idle Air Control Circuit input is below acceptable limits
could be as simple as a vacuum leak or as extensive as a wiring issue / idle control motor problem
Re: need NEON help [Re: gtx6970] #709473
05/27/10 07:47 PM
05/27/10 07:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Another possibility, happened on my 96 and my MIL's 98, is an EGR valve that is carboned up open.
Not sure if they fixed that issue by '01. Easy way to clean it is to dunk the mechanical part ONLY in MEK to soak and it'll clean out the carbon. DO NOT put the diagphram in the MEK or you will be buying a new one ($80+ last time I checked).
Steve
Don't be the exception.
Re: need NEON help [Re: Supercuda] #709474
05/27/10 08:54 PM
05/27/10 08:54 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Steve
MEK?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: need NEON help [Re: Magnumguy] #709475
05/27/10 09:05 PM
05/27/10 09:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Methyl Ethyl Ketone
if you can get it, wear gloves, do it outside, don't breathe the fumes
