8.75 Snubber #709205
05/27/10 10:04 AM
05/27/10 10:04 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
On a 72 Dart automatic strictly strip. Where should I have the Snubber? Distance to floor boards
Re: 8.75 Snubber [Re: flatiron] #709206
05/27/10 10:17 AM
05/27/10 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A snubber is a band aid for wear or shot springs
Re: 8.75 Snubber [Re: MR_P_BODY] #709207
05/27/10 10:24 AM
05/27/10 10:24 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I won't diagree with you about that as my springs are old. But I just built my first motor and the wallet is pretty empty at this time. I do have a set of Caltracs just need to save alittle more for the rest of the setup
Re: 8.75 Snubber [Re: flatiron] #709208
05/27/10 10:28 AM
05/27/10 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the Caltracs on with your springs... would be a
better way to go... JMO or if you want the snubber
and its a race car put it so it touches, that way it
lifts from the get go
EDIT
either way your going to need good shocks or its
all a waste.... it'll lift too fast
Re: 8.75 Snubber [Re: flatiron] #709209
05/27/10 10:52 AM
05/27/10 10:52 AM
Az
Crizila Offline
Crizila  Offline
Az
I run mine just touching. Welded a plate to the floor and cut the rubber snubber in half so it contacts the plate flat to flat. I run it with 3800 pound springs ( heavy B body automatic car ) with the front halfs clamped together. 50/50 shocks. I have no launch problems with my set up( 11.70 car ).
Fastest 300
Re: 8.75 Snubber [Re: Crizila] #709210
05/27/10 01:14 PM
05/27/10 01:14 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
ANOTHER snubber topic ? ..
HECK .... a set of TRACTION BARS are BESTer than a snubber.
Mr P ... said it ... NOTHING but a band-aid ....and NOT a very good one at that
Re: 8.75 Snubber [Re: BeEtLeJuIcE !] #709211
05/27/10 02:24 PM
05/27/10 02:24 PM
Az
Crizila Offline
Crizila  Offline
Az
Just trying to answer his original question. Not necessarily a proponent of pinion snubbers - Cal-tracs, 4 links, ladder bars, slapper bars, or ewectwic gitars!
Fastest 300
Re: 8.75 Snubber [Re: Crizila] #709212
05/27/10 02:29 PM
05/27/10 02:29 PM
Florida STAYcation
Florida STAYcation
THERE you go ... Criz....
A gitar strapped to the springs would work BESTer !!
But SERIOUSLY .... just get a GOOD set 'o springs ...and be done-with-it !!
Re: 8.75 Snubber [Re: flatiron] #709213
05/27/10 03:05 PM
05/27/10 03:05 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Put it in the garbadge can IMO. LOL Just saying what worked for me and many others for years.
Re: 8.75 Snubber [Re: HardcoreB] #709214
05/27/10 06:00 PM
05/27/10 06:00 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Mike, those S/S springs might have had 150 passes on them since they were installed. Since the car never went quicker than 13.74, I cannot see them being old or worn out.
Also, I had the snubber set about an 1 1/2" from the floor and since the car was set to rise at launch, it should have never touched it.
Then again, I don't know what all you have changed.
Re: 8.75 Snubber [Re: sixpakdodge] #709215
05/27/10 07:24 PM
05/27/10 07:24 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
If your straped for cash or just dont want ot go with the flow ,get a set of Comp type slapper bars.I know ,i know, forget what you have heard about how they dont work on Mopars.Im getting low to mid 1.5 60 foots on 8 inch slicks with a $35.00 set of Foxcraft bars that i got off of Craiglist here local.If you choose this route make sure you get a real comp set with the sping plates made to them and not the cheapo ones that just clamp to the springs ,because they dont work .The key is to get the snubbers right under the spring eyes and have them preloaded a tad with you in the car.Im using a transbrake at 3500 rpm and it dead hooks every time with no wheel hop on the tiny slicks with wore out 6 cylinder stock springs .I was only getting mid 1.6 60 foots without them.I have no doubt that my setup will hold a 1.4 60 foot as im almost there .My car lifts front and back when i drop the button and seems to work better the harder i hit it.I dont like pinion snubbers either BTW ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
