Power steering slams to the left (T/A) #70865
06/10/08 10:29 AM
06/10/08 10:29 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
The power steering on my T/A slams the wheel to the left. I am assuming the centering valve is stuck or shot. Any suggestions? Hoping to avoid a rebuild- I want to drive the dang thing finally- instead of opening another can of worms- Thanks guys- Kirby
Re: Power steering slams to the left (T/A) [Re: Kirby] #70866
06/10/08 01:07 PM
06/10/08 01:07 PM
cataclysm80 Offline
cataclysm80  Offline
Yes, sounds like the centering valve on top of the power steering unit. Full procedure is in the factory service manual, but the gist of it is to loosen the bolts holding it, (don't remove them, just loosen them) then tap the valve up or down (forward or rearward) on the steering box till it works like you want it to, then tighten the bolts back up. Sounds like it's all the way in one direction, and needs to go back the other way. use light tapping, A little bit goes a long way.
Tav
Re: Power steering slams to the left (T/A) [Re: cataclysm80] #70867
06/10/08 02:29 PM
06/10/08 02:29 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thanks Tav- I'll mess with it tonight-
Re: Power steering slams to the left (T/A) [Re: Kirby] #70868
06/10/08 03:40 PM
06/10/08 03:40 PM
Farmland, IN
Ludington1 Offline
Happy Birthday Ludington1  Offline
Farmland, IN
I agree with Tav... but don't loosen the bolts much, just BARELY loosen them and tab the valve. There's a bunch of pressure in there, I ended up with power steering fluid all over the place when I adjusted mine because I loosened the bolts too much.
Darren
Re: Power steering slams to the left (T/A) [Re: Ludington1] #70869
06/10/08 03:47 PM
06/10/08 03:47 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Just a little extra detail...Raise the tires off the ground so they don't add drag...If they are on the ground you'll get close but going down the road the car may drift due to a slight misadjustment...
Re: Power steering slams to the left (T/A) [Re: Kirby] #70870
06/10/08 04:41 PM
06/10/08 04:41 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Amazing how an unchallenged lie can become the absolute truth.
Re: Power steering slams to the left (T/A) [Re: beepbeep] #70871
06/11/08 09:34 AM
06/11/08 09:34 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thanks guys- Got it working last night. Had to take the top off- had a broken spring in there- works now. Will be driving it tonight- finally!
