Re: Merge Collectors
[Re: barryc]
#708362
05/26/10 02:11 PM
05/26/10 02:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Anybody have any good results with merge collectors? Are they worth it?
I've tested many different styles of collectors and if you have a set of purpose built headers for YOUR engine then they do help a fair bit... other than that the cost per HP gain isnt worth it (to me).... most people dont use a long enough collector in the first place.... off the shelf headers are WAY TOO SHORT when it comes to the collector
[Re: barryc]
#708364
05/26/10 02:54 PM
05/26/10 02:54 PM
MR_P_BODY
Does the old way for collectors still work? Mark them with cheap paint or crayon and cut them where it stops burning off?
NO... you would have to have a perfect tune for that to even be close... I know many guys say that it works but in reality its not close... for instance, if you are running fat do you think it would burn in the same place as if you were running lean... no way... headers are a mathematical and sound wave function
[Re: barryc]
#708368
05/26/10 03:41 PM
05/26/10 03:41 PM
MR_P_BODY
Short of trail and error, whats the best way to determine the correct length for a collector.
Send me a PM and I'll run your engine through my header program... I'll need some info
[Re: MR_P_BODY]
#708369
05/26/10 04:56 PM
05/26/10 04:56 PM
Posts: 872 Charlotte NC
DCI
Charlotte NC
Give me the bore, stroke, exhaust valve opening BTDC and peak power RPM I will run it in mine and give you the results as well.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block."
Those words must have left a bad taste in his mouth!
[Re: barryc]
#708371
05/26/10 07:42 PM
05/26/10 07:42 PM
DCI
Charlotte NC
4 into 1 header design:
Primary tube - 19.88" Primary Tube diameter - 2.58" Collector - 9.94" Collector diameter - 4.91"
Using the numbers you listed.
EDIT - made a calculation error. Had two kids begging for a golf cart ride and entered a value wrong. LOL
[Re: barryc]
#708373
05/26/10 09:20 PM
05/26/10 09:20 PM
Posts: 3,514 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Thanks for the info, but the car picked up when I went to a custom made 2" header. Primaries are 38 and collectors are 3 1/2.
The tube size quoted may be ID not OD, if so you may be closer than you think.
[Re: MR_P_BODY]
#708375
05/26/10 09:56 PM
05/26/10 09:56 PM
DCI
Charlotte NC
Using another calculator i have that only uses rpm, ci and BBDC value -
Your Primary Tube Length is 33.26 Your Primary Tube Diameter is 1.95 inches Your Collector Length is 16.63 inches Your Collector Diameter is 3.71 inches .
[Re: DCI]
#708376
05/26/10 10:04 PM
05/26/10 10:04 PM
MR_P_BODY
That is much more in line
[Re: MR_P_BODY]
#708377
05/26/10 10:54 PM
05/26/10 10:54 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Tubing is always OD EDIT A primary dia of 2.58 and a collector of 5"... most big blocks dont even go that big and this is a 422" small block that makes peak power at 6800
I gave my info to Mr P Body a while back for my 636ci and didn't get that big of numbers.;) He gave me around 2.5 primary and 4.5 collector. 410ci i'm guessing closer to 2 inch
