Re: Mopar 528 solid small block cam any users??
[Re: UCUDANT]
#70669
06/09/08 10:56 PM
06/09/08 10:56 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
FREE 509 cam in the box here no lifters...just pay shipping. Was given to me when I bought some heads from a guy. No lifters he took them for another engine
You have a pm
[Re: DusterKrazy]
#70675
06/10/08 05:58 PM
06/10/08 05:58 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
What was the combo on that mill??
My old set up with the 528 was as follows:
1963 Valiant 3250 lbs w/driver 360 bored 030 over Keith Black hypereutectic pistons / 10.3 compression stock rods and crank rotating assembly is balanced stock J heads with mild porting Mopar 284^ / 0.528" Solid cam stock mech. rockers from an old 273 Weiand Action Plus dual plane intake 750 Holley w/ vacuum secondaries Spitfire shorty headers running thru full length 2.5" exhaust A-904 tranny w/ 2.77 first gear set 10" ATI converter 3.91 gears with 26.1" tall ET Streets
This combo ran consistent 12.40-12.50's at Quaker City in Salem, Ohio
[Re: 340Scamp]
#70677
06/10/08 06:53 PM
06/10/08 06:53 PM
DusterKrazy
N.Wilkesboro,NC
I am running a purple shaft 571 solid lift with 304 duration in my 340. It is a street car it sounds awesome. The only down fall is you need a huge converter to run it. I would imagine the 528 will be a good cam for you
How much converter would you need?
[Re: 340Scamp]
#70679
06/10/08 07:35 PM
06/10/08 07:35 PM
Posts: 850 Georgetown, TX
sc4579
Georgetown, TX
I run that cam in my 360 with Edelbrock heads, Torquer II intake, KB107 pistons, in a 3100 lb Dart Sport. The car has a 904 trans with 4500 stall convertor and 4.88 gears and runs 7.50's in the 1/9 and 11.80's in the 1/4.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
[Re: sc4579]
#70680
06/10/08 07:37 PM
06/10/08 07:37 PM
DusterKrazy
N.Wilkesboro,NC
The 570 or 528 cam???
