Mopar 528 solid small block cam any users?? #70667
06/09/08 10:42 PM
06/09/08 10:42 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I was looking at cams and thought the 528 solid maybe a good cam for my 340 project. I believe it would have better vacumn and be more street worthy than the mopar 509. Any one here using this cam???
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70668
06/09/08 10:48 PM
06/09/08 10:48 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
FREE 509 cam in the box here no lifters...just pay shipping. Was given to me when I bought some heads from a guy. No lifters he took them for another engine
Re: Mopar 528 solid small block cam any users?? [Re: UCUDANT] #70669
06/09/08 10:56 PM
06/09/08 10:56 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
You have a pm
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70670
06/10/08 11:39 AM
06/10/08 11:39 AM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
I ran a 528 in my 360 and was very happy with it. Great street manners and was much tamer on the street than the 509.
Re: Mopar 528 solid small block cam any users?? [Re: Valiant_Showoff] #70671
06/10/08 11:43 AM
06/10/08 11:43 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
What was the combo on that mill??
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70672
06/10/08 01:38 PM
06/10/08 01:38 PM
Iowa
clarkj Offline
clarkj  Offline
Iowa
I had a 360 with 2.02 valved J heads, Eddy Performer air gap, headers, KB107 flat tops with the block milled to zero deck, and a Holly 650 on it in a lifted 4x4 truck with that 528 MP cam and LOVED it! I am re-using that cam in a 340 I am building right now. I hope it does as well as it did in my 360. The 360 idled with a slight lope, had loads of torque right off of idle and pulled hard to about 6200. I would highly recommend it
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70673
06/10/08 01:45 PM
06/10/08 01:45 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
My fathers 408 stroker has that cam. The engine is very well mannered and easy (to me at least) to drive on the street, even with a converter that flashes at 4500 rpm.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70674
06/10/08 03:10 PM
06/10/08 03:10 PM
Northern Ontario
Hans Offline
Hans  Offline
Northern Ontario
I'm running a .528 in my 408 and am very pleased with it. Have to idle at 1,100 but good vacuum.
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70675
06/10/08 05:58 PM
06/10/08 05:58 PM
Alliance, Ohio
V
V
Alliance, Ohio
My old set up with the 528 was as follows:
1963 Valiant
3250 lbs w/driver
360 bored 030 over
Keith Black hypereutectic pistons / 10.3 compression
stock rods and crank rotating assembly is balanced
stock J heads with mild porting
Mopar 284^ / 0.528" Solid cam
stock mech. rockers from an old 273
Weiand Action Plus dual plane intake
750 Holley w/ vacuum secondaries
Spitfire shorty headers running thru full length 2.5" exhaust
A-904 tranny w/ 2.77 first gear set
10" ATI converter
3.91 gears with 26.1" tall ET Streets
This combo ran consistent 12.40-12.50's at Quaker City in Salem, Ohio
Re: Mopar 528 solid small block cam any users?? [Re: Valiant_Showoff] #70676
06/10/08 06:44 PM
06/10/08 06:44 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
I am running a purple shaft 571 solid lift with 304 duration in my 340. It is a street car it sounds awesome. The only down fall is you need a huge converter to run it. I would imagine the 528 will be a good cam for you
Re: Mopar 528 solid small block cam any users?? [Re: 340Scamp] #70677
06/10/08 06:53 PM
06/10/08 06:53 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
How much converter would you need?
Re: Mopar 528 solid small block cam any users?? [Re: DusterKrazy] #70678
06/10/08 07:23 PM
06/10/08 07:23 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
I have a 4000 stall and don't think it's enough. People tell me I need a bigger converter. I cant really tell if it's big enough I unfortunately have not drove it on the street with the 4000 stall. I just got the new motor put in the car. Sorry this probably is not much help. I would say 4500 would probably be ideal.
Re: Mopar 528 solid small block cam any users?? [Re: 340Scamp] #70679
06/10/08 07:35 PM
06/10/08 07:35 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
I run that cam in my 360 with Edelbrock heads, Torquer II intake, KB107 pistons, in a 3100 lb Dart Sport. The car has a 904 trans with 4500 stall convertor and 4.88 gears and runs 7.50's in the 1/9 and 11.80's in the 1/4.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: Mopar 528 solid small block cam any users?? [Re: sc4579] #70680
06/10/08 07:37 PM
06/10/08 07:37 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
The 570 or 528 cam???
