440 Dual Quad Carbs 500cfm or 600cfm??? #706520
05/24/10 01:11 PM
05/24/10 01:11 PM
St. Catharines, ON
N
NewMemberAgain Offline OP
super street
super street
N
St. Catharines, ON
Hello all:
I have had for the past few years two old Carter 625 on an CH 28.
They are old and real gassy smelling, I go for a drive and smell like gas.
The carbs load up on me, need throttle shafts replaced, so rather than fix an old problem, I would rather go new.,
I have a 440 .50 over bore. 10.1 Ross Pistons, stock eddy heads, tri y`s and aar style exhaust in a 73 dart sport.
The motor is nothing fancy but we have taken alot of the `race`stuff off and have put the car back to a cruiser car.
Now with two kids on a Sunday drive we get gassed out. No fun.
I would like to think that the two 500`s would do the trick, as they are on the small side.
We run it progressive, so maybe the 600`would be a better choice, seeing as we run off the front carb, till I really get on it, which in the city is rare.
Either way, I need to eliminate the gassy smell.
I have read some posts from late 2008 and 2009 with Andy F`s big stroker 600hp and dual 500`s and thought I have only 450 hp and 451 cubic inches so maybe follow suit.
Any thoughts.
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: NewMemberAgain] #706521
05/24/10 02:34 PM
05/24/10 02:34 PM
I have read some posts from late 2008 and 2009 with Andy F`s big stroker 600hp and dual 500`s and thought I have only 450 hp and 451 cubic inches so maybe follow suit. Any thoughts.
go conservative, 500cfm X 2
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: NewMemberAgain] #706522
05/24/10 03:03 PM
05/24/10 03:03 PM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
500cfm is enough. I have two 600 edel on and they
tend to be to rich. have to use smaller jets.
but it is better to use smaller carbs und use bigger jets.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: NewMemberAgain] #706523
05/24/10 03:21 PM
05/24/10 03:21 PM
AndyF Offline
AndyF  Offline
Check out the article I just did for Popular Hot Rodding. July 2010 issue should be on the stand now. I used two 500 cfm Edelbrock carbs on an Edelbrock CH-28. That combo really ran nice and made great power.
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: AndyF] #706524
05/24/10 04:52 PM
05/24/10 04:52 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
You should be just fine with the Twin 500s...Its what I am running
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: Pyper70] #706525
05/24/10 08:56 PM
05/24/10 08:56 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm running 2 500's on a 440 very similar to yours. I'm very happy with the performance. I'm using the street hemi carb link to make the carbs "progressive". They work great.
Re: 440 Dual Quad Carbs 500cfm or 600cfm??? [Re: TooMany62s] #706526
05/25/10 12:58 AM
05/25/10 12:58 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I ran 2 500s on a 509 cammed motor. 3000 stall and 4:10s. Ran fantastic. Edelbrock Tech at a Lane Automotive car show told me 2 500s on a even a hot street 440 is plenty.
Keep old mopars alive.
Dual 500's. What about dual AVS? ( Thunder Series ) [Re: AndyF] #706527
05/25/10 12:40 PM
05/25/10 12:40 PM
St. Catharines, ON
N
super street
super street
N
St. Catharines, ON
Alright, well 500 cfm wins. Thanks for the replies back. ( As usual )
I read the wrong article Andy, I read Car Craft. It put another thought in my head, that being AVS.
It was a dual quad Chevy 409, and used two 500 Thunder Series AVS carbs.
I always enjoyed my old Holley 3310 750 VS on the street back in the old days.
Is going AVS a step back too much? They have them for single barrel and then ones calibrated for dual quad.
I do not run an electric choke, but it seems to be suggested, as also I am seeing a few electric chokes in the pics in the signature pictures.
Bryan
Thanks,
Bryan
