Page 1 of 4 1 2 3 4
HHR elec. fans "again"? #706227
05/24/10 12:58 AM
05/24/10 12:58 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Who out there is running one, who has the best prices, i looked on e-bay & only found 7" & 9" units, do they make them bigger?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: HHR elec. fans "again"? [Re: joedust451] #706228
05/24/10 01:04 AM
05/24/10 01:04 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think people were getting it for 60 something at rock auto
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: HHR elec. fans "again"? [Re: HealthServices] #706229
05/24/10 03:44 AM
05/24/10 03:44 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
the one i have is for a 2007 hhr. It takes up my entire radiator and it simply WORKS , these fans flow A LOT of air.
paid $60 for it new from rock auto.
Re: HHR elec. fans "again"? [Re: 493_DART] #706230
05/24/10 07:41 AM
05/24/10 07:41 AM
So Cal
So Cal
+9.40 shipping
Re: HHR elec. fans "again"? [Re: HealthServices] #706231
05/24/10 04:37 PM
05/24/10 04:37 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Does the hhr fan fit the 22" or the 26" radiator?
Re: HHR elec. fans "again"? [Re: rapom] #706232
05/24/10 04:41 PM
05/24/10 04:41 PM
So Cal
So Cal
It fits a Chevy HHR
Re: HHR elec. fans "again"? [Re: joedust451] #706233
05/24/10 05:29 PM
05/24/10 05:29 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
I just did it to my car. It's a little thick- close to the WP pulley, but it's trick. I paid the usual price from rock auto. (~$60). I also got the plug that fits for good looking wiring job. It fits right over a 22. I can see it working for a 26 also. The radiator is the 22'spectra, also from rock auto.
Re: HHR elec. fans "again"? [Re: WayneM] #706234
05/24/10 05:33 PM
05/24/10 05:33 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
another
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: HHR elec. fans "again"? [Re: WayneM] #706235
05/24/10 05:34 PM
05/24/10 05:34 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Installed.
2014 Durango R/T
Re: HHR elec. fans "again"? [Re: WayneM] #706236
05/24/10 07:11 PM
05/24/10 07:11 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
I'm running the same setup on a 26" radiator. I used some 2 X 2 aluminum angle and was able to use the factory fan shroud holes for mounting. I like my setup! That fan moves a lot of air.
Re: HHR elec. fans "again"? [Re: WayneM] #706237
05/24/10 08:40 PM
05/24/10 08:40 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Installed.
How did you strap it to the radiator, & did you have to trim it down, i've got 4" from the rad. cores too the WP pulley. One other thing, what amp alt. are you useing?
Re: HHR elec. fans "again"? [Re: joedust451] #706238
05/24/10 09:12 PM
05/24/10 09:12 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
The fan has hollow ribs that run up/ down. They line up perfectly with the stock shroud mount holes. I used 10/24 screws and nuts in each corner. I held the nuts with my long needlenose pliers. Needless to say, the rad and fan come out in one piece. Yes, I had to trim a lot. I took the motor out and trimmed away the back that covers the motor. Lots of trial fit.
The alternator is a basic 60 amp square back.
2014 Durango R/T
Re: HHR elec. fans "again"? [Re: WayneM] #706239
05/24/10 09:29 PM
05/24/10 09:29 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thanks, i'll most likely get one, what was the part #?
Re: HHR elec. fans "again"? [Re: joedust451] #706240
05/24/10 11:24 PM
05/24/10 11:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So how much room do you need to get it in there? I have a 16" fan from Mancini and I was looking into the HHR instead.Last Thursday it was over eighty here and my car went over 220 for a little bit until I got some fresh air in the grill.
Gus
64 Plymouth Savoy
Dana 60
Re: HHR elec. fans "again"? [Re: fourgearsavoy] #706241
05/25/10 12:30 AM
05/25/10 12:30 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Gus
About 3.1/2" after triming it down from what i'm seeing, there about 4", i'm sure your car has alot more room then my Dart, so it should fit fine.
Re: HHR elec. fans "again"? [Re: fourgearsavoy] #706242
05/25/10 03:08 AM
05/25/10 03:08 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Re: HHR elec. fans "again"? [Re: 493_DART] #706243
05/25/10 10:05 AM
05/25/10 10:05 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
I'm also wondering if my alt. will be enough, its just a stock unit, plob. about a 50 amper, all i'm running is a Mallory 6AL & msd dist., still running a mech. FB & WP.
Re: HHR elec. fans "again"? [Re: joedust451] #706244
05/25/10 11:52 AM
05/25/10 11:52 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
The factory male plug (the one NOT on the fan housing) is on many other GM cars at the U pull it. They gave me one for nothing. The Rock Auto site will let you see the applications if you look for them. Mine came with about 4 feet of both wires and came off a 1995 Buick.
Re: HHR elec. fans "again"? [Re: marvo451] #706245
05/26/10 01:04 PM
05/26/10 01:04 PM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
When you guys run this fan is it on all the time or can it be set up to opperate like a late model car so it kicks on when needed?
Ted
Re: HHR elec. fans "again"? [Re: DusTed74] #706246
05/26/10 08:04 PM
05/26/10 08:04 PM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
I bought an adjustable Derale fan controller from Summit for around $40. You can adjust the on and off temps.
Page 1 of 4 1 2 3 4
