Re: help,dropped bolt
[Re: barryv]
#705138
05/22/10 05:33 PM
05/22/10 05:33 PM
Posts: 533 SW CO
HemiSportFury
SW CO
If you are talking about the heat cross over, the opening in the center of the head on the intake side and not down the inside of the carb, they it is no problem at all. That is a blind hole around the crossover passage to reduce the heat transfer to the head.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: HemiSportFury]
#705139
05/22/10 05:38 PM
05/22/10 05:38 PM
Posts: 21,909 Kirkland, Washington
Pacnorthcuda
Exactly. If its in the "U" shaped area just get a magnet--I've pulled all sorts of crap out of these areas over the years. If it dropped into the exhaust crossover it may or may not be a problem. I would go after it with a magnet. May find a home harmlessly in the exhaust...then again, may rattle.
[Re: 1_WILD_RT]
#705143
05/22/10 08:27 PM
05/22/10 08:27 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Please clarify "it rolled into the head" as mentioned if it went into the upside down "U" shaped opening it won't hurt anything.. .
That 'U' opening is nothing but an air dam to help keep the hot adjacent exhaust ports from building up excessive heat.. They do not go internal.
[Re: barryv]
#705146
05/30/10 07:44 AM
05/30/10 07:44 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
i went fishing today for the dropped bolt in head. could not get it so i had to remove head. found bolt right away .now i have to put it all back. next time i will be more careful when working on cars
Lemme get this right. The screw (it's not a bolt): 1. fell down through the carb, 2. into the intake manifold, 3. down the plenum, 4. through an open valve, 5. and into the chamber....
[Re: Commando1]
#705149
05/31/10 09:08 AM
05/31/10 09:08 AM
Posts: 937 own private Idaho
ngpSatellite
own private Idaho
Don't feel bad. I once had the distributer out of my SB and a 4-40 X 1/8" screw fell down inside the block...
.... back in the day in the USAF, you would drop a scew in an F4 cockpit and you would have to call egress, pull the seat and sometimes take days looking for a tiny washer or screw now those were the days!!!
