Re: help,dropped bolt
[Re: HemiSportFury]
#705139
05/22/10 05:38 PM
05/22/10 05:38 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
If you are talking about the heat cross over, the opening in the center of the head on the intake side and not down the inside of the carb, they it is no problem at all. That is a blind hole around the crossover passage to reduce the heat transfer to the head.
Exactly. If its in the "U" shaped area just get a magnet--I've pulled all sorts of crap out of these areas over the years. If it dropped into the exhaust crossover it may or may not be a problem. I would go after it with a magnet. May find a home harmlessly in the exhaust...then again, may rattle.
Entire Thread
help,dropped bolt
barryv
05/22/10 09:28 PM
dssaa
05/22/10 09:31 PM
ledft79
05/31/10 02:31 PM
1970440six
05/22/10 09:33 PM
HemiSportFury
05/22/10 09:33 PM
Pacnorthcuda
05/22/10 09:38 PM
barryv
05/22/10 11:44 PM
1_WILD_RT
05/23/10 12:03 AM
Pyper70
05/23/10 12:07 AM
MoparforLife
05/23/10 12:27 AM
barryv
05/23/10 01:19 AM
barryv
05/29/10 10:36 PM
Commando1
05/30/10 11:44 AM
barryv
05/31/10 02:26 AM
Commando1
05/31/10 12:19 PM
ngpSatellite
05/31/10 01:08 PM
