rear engine mount? #705114
05/22/10 04:35 PM
05/22/10 04:35 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
finally put the driveline in after several years and the trans mount won't line up. The bolts pointing upward don't line up with the trans holes.I'm sure I'm missing something simple here hopefully can get back to it tomorrow.Car was a running driving car and is being put back together with all the same parts except a new poly mount. 74 duster 340 with 727 Thanks
Re: rear engine mount? [Re: snuggles] #705115
05/22/10 04:42 PM
05/22/10 04:42 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you tried turning the bracket around? Normally you attach the bracket to the trans loosely then line up the bracket in the crossmember and tighten everything down.
Re: rear engine mount? [Re: stumpy] #705116
05/22/10 04:55 PM
05/22/10 04:55 PM
Pizza Bucket
snuggles Offline OP
snuggles  Offline OP
Pizza Bucket
I can try to turn it I checked the fsm and looks right though.I did have the bracket attached loosely but couldn't get it lined up. I'll try againh tomorrow may just need a fresh perspective
Re: rear engine mount? [Re: snuggles] #705117
05/22/10 05:42 PM
05/22/10 05:42 PM
Grand Prairie,Texas
Grand Prairie,Texas
Could you have the crossmember in wrong side to.
Re: rear engine mount? [Re: stumpy] #705118
05/23/10 01:35 AM
05/23/10 01:35 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
How far off are you?
Re: rear engine mount? [Re: Jim_Lusk] #705119
05/23/10 01:43 AM
05/23/10 01:43 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Do you have the motor mount ears on the right sides of the engine block ears?
Re: rear engine mount? [Re: snuggles] #705120
05/24/10 10:01 AM
05/24/10 10:01 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
i had the same problem. the center to center on the bolts was way too large. turned out that the mount i bought was boxed wrong at the factory.
71 scamp big block with 915 heads 727 trans
