Master Cylinder #704424
05/21/10 04:38 PM
05/21/10 04:38 PM
Marion,N.C.
67chargerRandy Offline OP
Marion,N.C.
I insalled a new late model [screw on caps] MC on my 67 Charger, do I need a different push rod? I'm not geting a pedal.
Re: Master Cylinder [Re: 67chargerRandy] #704425
05/21/10 08:38 PM
05/21/10 08:38 PM
Pedal too low or it wont pump up?
Re: Master Cylinder [Re: RapidRobert] #704426
05/21/10 10:55 PM
05/21/10 10:55 PM
Marion,N.C.
Marion,N.C.
It won't pump up, I'm going to bench bleed it again and check the pushrod length.
Re: Master Cylinder [Re: 67chargerRandy] #704427
05/22/10 03:01 AM
05/22/10 03:01 AM
If you undo the p rod at the pedal and w the pedal "up" and the M/C piston at rest you'll see if you need an adjustable one to make up the difference. If you plug the M/C w 2 brass Edelman brand inverted flare male fitting from your parts house (only several $$), at that point if the M/C is bled out (and good) the pedal will be rock hard and have virtually no travel. Check the length/then plug the M/C/then bleed the wheels if still a prob
