road wheel restoration #704123
05/21/10 10:19 AM
05/21/10 10:19 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Would like to restore the black portion of my road wheels. Is there a correct black paint that I can use? Thanks
Re: road wheel restoration [Re: 70 buzz] #704124
05/21/10 11:13 AM
05/21/10 11:13 AM
The New Jersey Hinterlands
Sssnake383 Offline
Old and boring
Sssnake383  Offline
Old and boring
I am also interested to read responses to this question.
Re: road wheel restoration [Re: 70 buzz] #704125
05/21/10 11:15 AM
05/21/10 11:15 AM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i just used an RM satin black with a hardener, no clear. removed the paint, polished them up, masked them off and sprayed them with a gun.
Re: road wheel restoration [Re: joelson6] #704126
05/21/10 03:27 PM
05/21/10 03:27 PM
Krylon 1613 satin black
Re: road wheel restoration [Re: 70 buzz] #704127
05/21/10 06:56 PM
05/21/10 06:56 PM
Chicagoland
cudastruction Offline
Chicagoland
I did this many years ago and got spraypaint from Totally Auto Inc. Looks great.
Re: road wheel restoration [Re: cudastruction] #704128
06/16/10 12:01 PM
06/16/10 12:01 PM
Waukesha, WI
77aspenRT Offline
77aspenRT  Offline
Waukesha, WI
I have as set of road wheels that I want to freshen up for my current project. I have the black paint for the inserts and the front lip of the wheel has an industrial gray appearance. Does anyone know if the rear inner portion of the wheel was painted or bare? If it was painted, what color?
Re: road wheel restoration [Re: 77aspenRT] #704129
06/16/10 12:17 PM
06/16/10 12:17 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
On the early wheels the "hoop" was black, if you are doing a set for your Aspen they may be gray. On the black "hoop" wheels there is a tape/mask line ~1/4" onto the plated center both front & back.
Is it as simple as 5.5" wide = BLACK & 6.0" wide = GRAY
Re: road wheel restoration [Re: 6bblgt] #704130
06/16/10 02:56 PM
06/16/10 02:56 PM
Waukesha, WI
77aspenRT Offline
77aspenRT  Offline
Waukesha, WI
I have Rallyes on the R/T. These are for my Volare Road Runner project. Your probably right on track with the gray. I removed the tires and the surface is also industrial gray looking. The back side is just hard to tell from all the rust and grease/grime.
