Moving the trans cooler to help cool the engine? #70370
06/09/08 11:33 AM
06/09/08 11:33 AM
North Riverside IL & Lowell IN
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
If I get suck in traffic the temprature starts to climb and stays high until I get moving again. I have a big old super cooler mounted to the front of the radiator and was wondering how much this might improve if I move it from in front of the radiator.
Has anyone else had a similar situation?
Ken
Re: Moving the trans cooler to help cool the engine? [Re: GTXKen] #70371
06/09/08 02:08 PM
06/09/08 02:08 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I have a trans cooler in front of my radiator on my 70 road runner and am having the same issue you are.
So i am curious for the answer to this also....at the very least the post is bumped back to the top.
Re: Moving the trans cooler to help cool the engine? [Re: GTXKen] #70372
06/09/08 09:14 PM
06/09/08 09:14 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
What is the rest of you cooling components and engine size? How much horsepower and torque converter stall speed. You may not have the correct components to keep this thing cool. What size radiator, fan, shroud, thermostat? My cooler is located in front of my radiator and cooling is not an issue.185-190 max temps in Fl. 493 3500 stall converter.
Re: Moving the trans cooler to help cool the engine? [Re: Bdrainy] #70373
06/09/08 09:20 PM
06/09/08 09:20 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You don't want to move the trans coolers, it needs to be up front for the transmissions sake. I have had the same high engine temp problem with my 360 B'cuda. I have a 904 with a 9.5" Dynamic converter (more heat). I have made 2 changes this month that have cooled things down considerably. First, I found a deep trans pan on Egag that has an extra quart capacity AND cooling tubes that run through the pan, front to back. Literature that came with the pan says it reduces trans temp 20 to 50 degrees. So you are getting rid of some trans heat at the source before it ever gets to the radiator and coolers out front. Second, I changed from 20w50 diesel motor oil to 10w30 Pennzoil and added a bottle of ZDDPlus additive. Oil pressure is still good, and the thinner oil and lower pressure dropped the engine temps further. I had it out for a run last weekend in 90*+ weather, and it did not go past 2/3 to H. Now to fix my fuel delivery problems
EDIT. Also, when sitting in traffic, shift to neutral. The idle will pick up slightly, and the engine will stop lugging against the converter/trans. Both should help cooling at least a little.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Moving the trans cooler to help cool the engine? [Re: Bdrainy] #70374
06/09/08 10:12 PM
06/09/08 10:12 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I have the same problem as the first 2 posters, and a BIG trans cooler right in front of my radiator, behind the grill, which is where I reckon the radiator gets most of the air from since there's a giant bumper blocking the lower part.
There are some guys (Goody if I remember right) who are using the stacked plate style cooler and located it in their wheel well where it gets airflow, but is not in front of the radiator.
I am in the middle of installing a clutch fan in my car, and a shroud. If after that I still have cooling problems I'm going to get a smaller trans cooler and put it in the wheelwell. I dunno about the other guys but I already have a deep trans pan..
Re: Moving the trans cooler to help cool the engine? [Re: Exit1965] #70375
06/09/08 11:24 PM
06/09/08 11:24 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Its good to have a few inches of airgap between the two.
Re: Moving the trans cooler to help cool the engine? [Re: earlybee] #70376
06/09/08 11:51 PM
06/09/08 11:51 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think the problem on a car, is where do you move it to?
I think I've seen some of the southern guys say they have moved thiers with sucess. Perhaps one of them will chime in.
I mounted a remote trans cooler on my tow rig winni.
I used a trans cooler from a 06 f350 superduty diesel. It's about the same size as a K car radiator. That said, I mounted an electric fan on it from a K car. I moved it so it is behind the rear diff, under the motor home.
It's not rocket science. If the cooler is in front of the rad, it takes the heat out of the trans, and puts it straight back into the rad. By moving the cooler, so it is totally independant, it only removes heat from the trans. Does not ad it to the motor. Preheated air for the radiator can't be effecient, as seen when the AC is on.
How good does it work? Well, I only kick the fan on, when on the hills to help keep the trans from boiling(common in motor homes). Keeps my engine temps constant when pulling the car.
When I got to a 50 mile flat stretch after a bunch of hill climbing last year, I kicked it on just for fun. Dropped the engine temp 10 degrees.
I'm pretty sure there are small coolers with electric fans already built on them available from speed shops, online etc..
Re: Moving the trans cooler to help cool the engine? [Re: GO_Fish] #70377
06/10/08 12:27 AM
06/10/08 12:27 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
in neutral the pump doesn't flow enough,you are better off in gear with the pump at max psi.
Re: Moving the trans cooler to help cool the engine? [Re: west] #70378
06/10/08 10:52 AM
06/10/08 10:52 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I'm running a stock radiator (read old) right now with a new shrowd and clutch fan on a 505 with a 3800 stall converter, I ordered a new radiator and I'll see where that gets me befor I move the cooler
Re: Moving the trans cooler to help cool the engine? [Re: GTXKen] #70379
06/10/08 02:29 PM
06/10/08 02:29 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
Is your radiator a 22" or 26"? (not sure if 22" even came in GTX's....) I have been looking for a new radiator for my roadrunner also, do you mind me asking which one you went with? Aluminum?
Re: Moving the trans cooler to help cool the engine? [Re: Bdrainy] #70380
06/10/08 02:35 PM
06/10/08 02:35 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Sock is 26", I bought an aluminum 26" off of ebay but now after talking to Don at FBO I may be returning it, he is recurving a distributer for me and said that it will more than likely take care of my heat issues. We'll see
Re: Moving the trans cooler to help cool the engine? [Re: GO_Fish] #70381
06/10/08 02:42 PM
06/10/08 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
this is a very good idea but the biggest heat source is the torque convertor and it pumps fluid to the cooler before it gets back to the pan .
Re: Moving the trans cooler to help cool the engine? [Re: GTXKen] #70382
06/10/08 02:44 PM
06/10/08 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm running a stock radiator (read old) right now with a new shrowd and clutch fan on a 505 with a 3800 stall converter, I ordered a new radiator and I'll see where that gets me before I move the cooler
old rad , let me guess , 2 row ?
i think what ever don is doing is not going to be the cure all , a 505 inch motor needs a good cooling system. A better rad , a shroud , a good fan and a hi flow pump is going to be required also.
Re: Moving the trans cooler to help cool the engine? [Re: JohnRR] #70383
06/10/08 02:50 PM
06/10/08 02:50 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Yeah, two row. I am running a shroud, good fan and hi flow pump. I'm not banking on the distributer to be the cure all but I will change it first and see what impact that has before I do anything else.
I have seen two many guys make tons of changes all at once and end up with little or nothing corected. I'll make changes one at a time.
I'll let you know
Re: Moving the trans cooler to help cool the engine? [Re: JohnRR] #70384
06/11/08 07:56 PM
06/11/08 07:56 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Okay, sounds like my thinking was bass ackwards. Not the first time (or last) . But still, any heat shed beneath the car is heat you are getting out of the cooling system eventually.
