Oil Pan Rust - 2004 Dodge Ram Hemi
#703134
05/20/10 10:58 AM
05/20/10 10:58 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Ive owned the truck since new 2004 Hemi Sport Quad Cab 4wd
Truck has 33,000 original miles - I do all my own oil changes , maintenance (My Dodge Dealer this past fall went thru the Rearend/Issues under warranty and then serviced the front axle and transfer case) - I guess this past winter , the salt on the roads really took its toll on the oil pan I guess i just didnt notice it as much in the past
Anyways
The oil pan - I was speechless - I am not talking surface rust - I am talking serious bubbling corrosion in the area of the drain plug flat area - Looks like serious body rust in areas
All the years of wrenching i have never seen a oil pan rust like this on ANY vehicle
Whats this thing going to look like after a few more winters ???
Anyone get one of these replaced under warranty ??? Or would it bee a dead issue
I have the bumper to bumber 7 year 70,000 mile warranty i bought when new
Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: Oil Pan Rust - 2004 Dodge Ram Hemi
[Re: bee1971]
#703135
05/20/10 12:52 PM
05/20/10 12:52 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I don't think warranty will cover it unless it is leaking. Least hassle for you at this point will be to get under there with a wire wheel, then shoot it with Rustoleum. The oil pan rusted through on my old 95 Dakota, I wish I had addressed it sooner, would have been a lot less work/ cheaper.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: bee1971]
#703137
05/20/10 01:02 PM
05/20/10 01:02 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
My '03 is like that too but mine has 229,000 miles on it, so actually it's probably worse. It's really ugly but it probably won't leak for many years after the bubbling starts because the pans are actually laminated/made from "quiet steel".......a layer of nasty plastic goop sandwiched between two layers of steel. So you're only seeing the outside of it....the inside layer is probably still in perfect shape. The nasty plastic goop stuff (also known as engineered multilayer composites with various viscoelastic cores) tends to protect the inner layer pretty darn well. The outer layer can be pretty trashed and it won't leak. http://www.quietsteel.com/quietsteel.html
Rich H.
Esse Quam Videri
