'65 Coronet...largest slick in stock wheel well? #702665
05/19/10 07:41 PM
05/19/10 07:41 PM
Philadelphia,PA
MoparJim Offline OP
MoparJim  Offline OP
Philadelphia,PA
What is the biggest slick{height and width} which will fit in a stock wheel well on a '65 Coronet?
How about stock spring location and with springs moved in? Pictures would be greatly appreciated. Thanks for the help.
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702666
05/19/10 07:49 PM
05/19/10 07:49 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have a 29x10.5" in a '65 Post, stock spring location. They do rub a little.
Re: '65 Coronet...largest slick in stock wheel well? [Re: sixpakdodge] #702667
05/19/10 07:57 PM
05/19/10 07:57 PM
Philadelphia,PA
MoparJim Offline OP
MoparJim  Offline OP
Philadelphia,PA
Where do they rub?
Re: '65 Coronet...largest slick in stock wheel well? [Re: sixpakdodge] #702668
05/19/10 08:25 PM
05/19/10 08:25 PM
fullmetaljacket Offline
Try Dr. Diff inboard kit which moves the springs in by about a 1/2 inch in on both sides. All you have to do is weld the spring perches in by a 1/2"
Every thing else is a bolt on.
It worked great on my stock well 65'sedan.
I run the Hoosier QTP 11.5 x 28 inch tire on a 8" rim with 5-1/2 inc h back space, no rubby ducky.
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702669
05/19/10 09:51 PM
05/19/10 09:51 PM
AndyF Offline
AndyF  Offline
You can put a pretty big tire back there once you move the inner wheel well over so it lines up with the frame. Until you do that you'll fight for clearance.
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702670
05/19/10 10:32 PM
05/19/10 10:32 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
m&h n50/15 on a 10" wide wheel ,12" section width , stock wheel houses with springs moved in.
Re: '65 Coronet...largest slick in stock wheel well? [Re: johnzgarage] #702671
05/19/10 11:20 PM
05/19/10 11:20 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
here is a pic of my old 65 Plymouth. with the springs moved in 3 inches per side and the wheel wells Minni tubed. The wheels wear weld pro stars 15x10 with 6.5 inches of BS and M/T 31x10.5X15W slicks. I did have to trim the front of the lower wheel well so the slicks would not rub and it only took a little bit to get them to clear. here are some pics of it. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: '65 Coronet...largest slick in stock wheel well? [Re: mopar65] #702672
05/19/10 11:21 PM
05/19/10 11:21 PM
mopar65 Offline
mopar65  Offline
side pic. Mopar65
Re: '65 Coronet...largest slick in stock wheel well? [Re: mopar65] #702673
05/19/10 11:24 PM
05/19/10 11:24 PM
mopar65 Offline
mopar65  Offline
also with every thing stock and the inner fender lip rolled in i could run a M/T 30x9 slick with a 15x7 steel wheel. it has been so long that i for got the BS on the wheels tough. Mopar65
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702674
05/20/10 01:15 AM
05/20/10 01:15 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Here is my 65 with 32x 14.5W's LOL...leaf springs...Ok, you got me... the wheel well's are slightly modified
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702675
05/20/10 07:58 AM
05/20/10 07:58 AM
Mountains of NM
65superstock Offline
Mountains of NM
Not a slick, but with the springs moved in 3" I can fit the MT ET street radial P275/60R15 on weld 10" rims with 5.5" of backspace. Nothing done to the wheel well or the lip.
Re: '65 Coronet...largest slick in stock wheel well? [Re: 65superstock] #702676
05/20/10 09:25 AM
05/20/10 09:25 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'm gonna say a 28" tall 9" slick on 15x8 wheels with a 4 1/2" backspace for a totally stock wheel well is safe. i've used 275-60x15's on a 15x8 4 1/2 backspace on the stock wheel wells and spring location and its probably the most i'd safely use.
Re: '65 Coronet...largest slick in stock wheel well? [Re: lewtot184] #702677
05/20/10 10:54 AM
05/20/10 10:54 AM
Philadelphia,PA
MoparJim Offline OP
MoparJim  Offline OP
Philadelphia,PA
Thanks everyone.
Re: '65 Coronet...largest slick in stock wheel well? [Re: MoparJim] #702678
05/20/10 05:43 PM
05/20/10 05:43 PM
Long Island, NY.
Stroked65Belv Offline
Long Island, NY.
The pic of my 65 had 275/60-15s on a 10" rim. It was tight! I went to a Hoosier QTP 29x10.5-15 and had to mount on a 8" rim (which was the minimum recommended in their catalog) and it fit great with room to stick your hand in between tire and qtr. I think it was 4.5 backspace. It looks great now, really fills the well. Sorry no pics yet of new set up. Springs in stock location and only the lip of quarter had been rolled a lil.
