It's in, running and has too high oil pressure???
#702566
05/19/10 05:42 PM
05/19/10 05:42 PM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
It's finally all together, in the car and running. It was actually in and fired up last week but I had a rocker adjuster break. So finally UPS dropped off the the ones and I re-fired it up. It sounds good but seems to have unusually high oil pressure. Since the episode of the windage tray piece braking off I have replaced all new bearings, rings, polished the crank, and R&R the heads. The old oil pump used to have 65 LBS hot or cold. The new one has about 75 at idle and seems to go over 100 if you rap it. I got the motor up to 160*. I'm using Rotella 15/40 in it. I'm gonna switch to a straight 30 wt. Any thoughts on this?? I have yet to get the car to the track and really put some heat in it. But, I still think that's a little high though??? DC
Re: It's in, running and has too high oil pressure???
[Re: dc426]
#702569
05/19/10 05:56 PM
05/19/10 05:56 PM
Quicktree
Melling high volume pump. Same as what was in there before.
thats probably your problem. these new hv pumps have a lot of pressure.
[Re: dc426]
#702572
05/19/10 06:06 PM
05/19/10 06:06 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I can't see that oil pressure hurting anything. Seems fine to me. I have an adjustable external deal on my B1, and just for kicks, tried back to back runs with oil pressure 75 and 100+.. There was ZERO difference in ET.. So why stress over nothing.. Chris..
[Re: Chris'sBarracuda]
#702573
05/19/10 06:47 PM
05/19/10 06:47 PM
Posts: 1,880 USA
Ron Silva
USA
I would never run straight 30 weight. I would go to 5W30 or maybe the 10W30 Valvoline racing oil and if your water temp was 160 that means nothing. The oil temp could still be way lower than that. Drive it for 30 minutes and report back.
SRT DEMON ONE SEAT
[Re: dc426]
#702575
05/19/10 07:00 PM
05/19/10 07:00 PM
Posts: 16,923 NC
440Jim
NC
Switching to straight 30 wt will make the cold pressure even higher. I would stick with the 15W-40.
Put the relief spring from the old pump in the new pump. The new pump spring is likely different.
[Re: Ron Silva]
#702576
05/19/10 07:01 PM
05/19/10 07:01 PM
Posts: 5,875 communist bloc of new jersey
jamesc
agreed, fwiw i believe the shell 15-40 is pretty decent oil. also as mentioned if the oil temp wasn't up is could contribute.
[Re: jamesc]
#702577
05/19/10 07:07 PM
05/19/10 07:07 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Chris I just went through this myself my HV pump was pushing 80 psi cold at idle and well over 100 and the relief was not sticking as I pulled the pump apart and cleaned it. I ended up putting a standard pump in mine but before I did I put a 5w30 in it and that helped a lot ran it for a few weeks like that before I pulled and replaced the pump. I found out a standard pump will do just fine with a little clean up and it uses less HP to turn. My standard pump with 10w40 engine hot holds 40 psi at idle and almost 80 down track.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#702578
05/19/10 07:26 PM
05/19/10 07:26 PM
Quicktree
Chris..
well having blown 3 filters apart in 2 weeks at the track during a burn out the guys get pissed in a hurry I bet Myron remembers that. I made changes to the springs every time. ended up with a stock pump and spring to solve the problem. it does matter and dangerous to boot.
[Re: dc426]
#702579
05/19/10 07:49 PM
05/19/10 07:49 PM
I didn't but when I fired it up the other day before the rocker adjuster broke it was pretty much normal. Had 75 constant.
are you saying you re-used the same pump but didn't take it apart to thoroughly clean and remove any metal that might have been trapped in it? if you did, i guess you know where that metal could end up.
please, say it ain't so...
[Re: Quicktree]
#702582
05/19/10 08:18 PM
05/19/10 08:18 PM
Chris'sBarracuda
Arizona
Chris..
System 1
Chiris..
#702583
05/19/10 08:30 PM
05/19/10 08:30 PM
Quicktree
Chris..
System 1
Chiris..
thats what we changed to after the 3rd time
#702584
05/19/10 08:37 PM
05/19/10 08:37 PM
dc426
Tampa Florida
Of course not. I bought a new Melling HV pump.
[Re: Quicktree]
#702585
05/19/10 08:45 PM
05/19/10 08:45 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Chris..
System 1
Chiris..
CH!T Tony even I learned after the second time
I run straight 70 and have 200lbs of pressure.
Jimmy
