91 Spirit...speedo and odometer not working... #70180
06/08/08 10:49 PM
06/08/08 10:49 PM
Anacortes, WA
russ71satellite Offline OP
Anacortes, WA
Is the speed/distance sensor about the only likely cause of a speedo and odometer not working in a 91 Spirit?
Thanks for the help..
71 Satellite Sebring, all stock
1989 Dodge Daytona, daily driver
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70181
06/09/08 12:58 AM
06/09/08 12:58 AM
broken/siezed cable.
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70182
06/09/08 10:22 AM
06/09/08 10:22 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I dont think 91 has a cable. Its driven electronicly via a speed sensor.
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70183
06/09/08 01:49 PM
06/09/08 01:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used to have a 91 Daytona and the speedo acted up. Sometimes it wouldn't work, sometimes it would. Sometimes while decellerating from 70mph the speedo would stick on 70 for a while before dropping to normal. I put a speed sensor in it and didn't have any more problems. Hope that helps!
Re: 91 Spirit...speedo and odometer not working... [Re: burdar] #70184
06/09/08 04:48 PM
06/09/08 04:48 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Don't wanna hijack, but I was gonna post this question as well. 97 Neon, same symptoms as above,except for the sticking. Is it worth the time to remove the sensor and clean connections, or should I just replace it?
Nothing to see here. Carry on.
Re: 91 Spirit...speedo and odometer not working... [Re: JD340] #70185
06/09/08 04:51 PM
06/09/08 04:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You should check for fault codes first. If there is one it could be a sensor. Also verify if the odometer does not work at the same time. If it does work and the mph needle does not the problem could be in the speedo head/cluster.
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70186
06/09/08 05:36 PM
06/09/08 05:36 PM
JD340 Offline
JD340  Offline
"You should check for fault codes first. If there is one it could be a sensor. Also verify if the odometer does not work at the same time. If it does work and the mph needle does not the problem could be in the speedo head/cluster."
When the speedo quits, the odo and trip meter also quit. Have scanner, will check! Now, will scanner show a code if the speedo IS working at the time I plug in the scanner? Or only when the speedo is dead?
Re: 91 Spirit...speedo and odometer not working... [Re: JD340] #70187
06/09/08 06:00 PM
06/09/08 06:00 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If the speedo does not work the computer should induce and store a code.
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70188
06/09/08 07:15 PM
06/09/08 07:15 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Most likly the speed sensor, they go bad ALL the time.
Re: 91 Spirit...speedo and odometer not working... [Re: rrunner] #70189
06/10/08 12:09 AM
06/10/08 12:09 AM
Anacortes, WA
Anacortes, WA
thanks for the info...yep, this car does not have a cable.
Could it also be a broken tooth on the gears in the speedo? I hope not...
2008 PT Cruiser
Re: 91 Spirit...speedo and odometer not working... [Re: russ71satellite] #70190
06/10/08 12:12 AM
06/10/08 12:12 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
speed sensor is a very common failure on these.
Gears, not so much, but always a possibility.
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70191
06/10/08 12:37 PM
06/10/08 12:37 PM
JD340 Offline
JD340  Offline
Scanned it this morning. No codes. No speedo,odo, etc for most of the time I was running around this morning. Came back to life a couple miles from home. I'll order up the speed sensor. Hopefully it does the trick.
Re: 91 Spirit...speedo and odometer not working... [Re: JD340] #70192
06/10/08 12:48 PM
06/10/08 12:48 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If the speed sensor pops back to life at all, even for a second, it'll automatically clear the code in the computer. Mine was like that too, intermittantly dieing, changed speed sensor and all was good.
Re: 91 Spirit...speedo and odometer not working... [Re: DaytonaTurbo] #70193
06/10/08 01:07 PM
06/10/08 01:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is kinda 'backyard' but if you have cruise, set the cruise control. If the car goes out of cruise when the gauges die, it could be the speed sensor. If the car does not drop out of cruise, then it's probably the gauge cluster. As to the Neon cluster, Google something like 'Neon gauge problem'. This failure seems to be common.
Re: 91 Spirit...speedo and odometer not working... [Re: DaytonaTurbo] #70194
06/10/08 01:11 PM
06/10/08 01:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It will not automaticly clear the code. The code will stay for aprox 50 ignition cycles.
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70195
06/10/08 01:55 PM
06/10/08 01:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Just a piece of info I run a trans shop and have had many chrylers come in with speedo problems speedo not working and they had not set one code at all put the scanner on and go to data and no reading from output sensor but no codes so just because there is not a code that doent mean the speed sensor isnt bad.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70196
06/10/08 03:47 PM
06/10/08 03:47 PM
Manitoba, Canada
Manitoba, Canada
Sure about that? Cause mine never set a code and I checked it a few times. But change the sensor and problem was gone forever...?
Re: 91 Spirit...speedo and odometer not working... [Re: DaytonaTurbo] #70197
06/10/08 04:05 PM
06/10/08 04:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes. Once the code is set and the problem iscorrected or does not happen again you have to either reset with a scan tool or the older ones should clear in 50 ignition cycles.
Read your post. You said it automaticly clears itself.
Re: 91 Spirit...speedo and odometer not working... [Re: NITROUSN] #70198
06/10/08 06:49 PM
06/10/08 06:49 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
I had a 94 spirit and the same thing happened to me. I never did figure it out. I think my car had a short in the dash but I'm not sure.
Re: 91 Spirit...speedo and odometer not working... [Re: 340Scamp] #70199
06/10/08 07:48 PM
06/10/08 07:48 PM
Kissimmee Fl.
Kissimmee Fl.
like I said above I have had a number of them in the shop with bad speed sensor that never set a code
