Post deleted by Defbob
[Re: 340minihemi]
#701604
05/18/10 08:57 PM
05/18/10 08:57 PM
Re: 440 Build advice
#701605
05/18/10 09:45 PM
05/18/10 09:45 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
10.1 comp might be to much with iron heads, unless you don't mind running GOOD gas all the time.
I will agree with this, especially given the fairly mild camshaft that has been suggested.
A little more cam, and it'll run on pump gas with iron heads.
#701607
05/18/10 10:40 PM
05/18/10 10:40 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Nonsense. Whatever CR you have with aluminum heads you can have with iron heads. I wish someone would put this myth to bed. Manufactuers were running up to 12:1 in the sixties. With iron heads.
[Re: Commando1]
#701608
05/18/10 10:51 PM
05/18/10 10:51 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
and with sixties gas
[Re: 340minihemi]
#701609
05/19/10 02:14 AM
05/19/10 02:14 AM
RapidRobert
get quench. It'll be a pita w open chambers as the OC head recesses need to be machined to equalize the slope/depth of them then machine the KB quench pads and several mockups (why I like floating pins) and carefull measuring to get .035-040" on each cyl but this will give you a spot on foundation (long block) that'll let you run the most static CR and in the end the highest DCR that will function wo pinging w your choice of octane as slowing your timing to compromise this is a band aid that severely hurts power
[Re: dave571]
#701610
05/19/10 09:24 AM
05/19/10 09:24 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
[Re: rss]
#701611
05/19/10 11:44 AM
05/19/10 11:44 AM
Dodgem
Ontario, Canada
some people should not post answers when they are wrong and or don't know!
[Re: Dodgem]
#701612
05/19/10 12:19 PM
05/19/10 12:19 PM
Commando1
Whether gas was better or not has nothing to do with what we are talking about.
The comment was made:
10.1 comp might be to much with iron heads...
I said that iron heads were as high as 12:1 in the 60's.
W*T*F does that have to do with the quality of gasoline?
YOU don't know what you are talking about.
But don't take it from me. Here: Iron vs aluminum heads
guess what we learned? ...zero difference anywhere in the power or detonation characteristics of the iron versus aluminum heads
some people should not post at all when they are wrong and or don't know!
[Re: Commando1]
#701613
05/19/10 02:26 PM
05/19/10 02:26 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Dude, quit while you're behind.
Gas was 106+ octane in the 60's. Now it's 93/94 at best.
No one is going to get away with 12:1 with iron heads on a street motor.
[Re: Commando1]
#701615
05/19/10 02:28 PM
05/19/10 02:28 PM
rss
Seattle, WA
Not really relevant since they used a much more aggresive cam that would help to bleed off some cyclinder pressure as was suggested by previous posters.
Check out KB pistons site. They have tech article with recommended compression ratios and sure seem to believe there is a difference between cast iron and aluminum heads. I'd believe KB before I'd believe some mag article done using a long duration cam.
#701617
05/19/10 02:43 PM
05/19/10 02:43 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I was running 15.5 in my 440 with Iron heads.It ran on 93 octane.I really couldnt hammer it on the street as it would have clatter but for just driving it was OK.I do have a big cam at .588.With the aluminum heads its much better.I do have to agree anout 10 to 1 is about all you want in a mild build.My kids 62 300 413 runs about that and it never clatters.Rocky
Chrysler Firepower
[Re: 64Post]
#701618
05/19/10 03:52 PM
05/19/10 03:52 PM
Posts: 90 NL
Frederick
NL
That carcraft test doesn't prove anything. They are to far away from the detonation limit with 260@0.050 and only 10.88:1 compression. They are even admitting it on the second page: "We're not going to be quite so cocky about debunking the claim that you can run higher compression on pump gas with aluminum than with iron. Our test does not definitively prove that. It may not have even tested it."
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
[Re: Commando1]
#701620
05/19/10 05:45 PM
05/19/10 05:45 PM
KB237's usually make nearer 9.6--9.7 with a trued up 452 head deal--get the distributor curve just right and premium pump is easy without the quench saga--IF you do a perfect quench deal it gives you an edge but normal dudes in the back yard can run fast and without trouble by getting the curve right ( many ways and folks to do this like FBO) ---I agree that NO way with 10% ( and SOON to be 15% alky ) that you can run any more CR than this and be safe--quench will help but the gas we buy WILL be 15% sooner than you wear that thing out so get ready and plan ahead.......Turning the timing back to keep a higher CR from killing itself knocking--just guts it---no way around it...........
[Re: StealthWedge67]
#701622
05/19/10 08:48 PM
05/19/10 08:48 PM
Commando1
Now, you're not going to get away with 12:1 compression on pump gas no matter what heads you run.
You can't read. I never said that you could run 12:1 on today's gas. Go back and look. I keep saying that using aluminum heads is NOT an advantage over iron heads on today's lower octane gas, whether they are BOTH 8:1, 10:1, or 12:1. You just have a woody over aluminum heads without knowing why.
