Squeaking is driving me crazy (leaf spring bushing) #700799
05/17/10 07:49 PM
05/17/10 07:49 PM
BDW Online content OP
BDW  Online Content OP
I put new ESPO springs in about a yr ago. They have always squeaked from day 1. It's really driving me crazy. It seems like the majority of the noise is coming from the frt bushing area.
FSM says to NOT lube rubber bushings (which they are).
Any ideas?
Thx
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: BDW] #700800
05/17/10 08:46 PM
05/17/10 08:46 PM
FSM says to NOT lube rubber bushings (which they are).Any ideas?
(1) they mean oil/grease (2) some rubber lube of some sort would take care of it, not sure exactly what's available but not a critical area (ex for the noise of course)
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: RapidRobert] #700801
05/18/10 05:48 AM
05/18/10 05:48 AM
Middle of the mitten
69DodgeCharger Offline
I've soaked the bushings with dishsoap and then rinsed them off with good results before.
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: 69DodgeCharger] #700802
05/18/10 06:18 AM
05/18/10 06:18 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
silicone spray might work
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: BDW] #700803
05/18/10 06:52 AM
05/18/10 06:52 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
just a thought, loosen all the mounting hardware and with the weight of the car on the ground (not jacked up with the suspension hanging) tighten it back up.
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: BDW] #700804
05/18/10 08:37 AM
05/18/10 08:37 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
An old car dealers service department trick: Sqirt it with automatic transmission fluid. Never seen it fail.
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: Commando1] #700805
05/18/10 05:50 PM
05/18/10 05:50 PM
I called ESPO and she said she had NEVER heard of the rubber bushing squeaking. Said it was impossible because there are 2 metal sleeves, inner where the bolt passes through, and the outer which is pressed in the leaf spring.
I'm going to take a closer look to see if the metal is actually moving. It's definitely coming from the area.
I can't tell you how annoying it is. I understand now when people say to stay away from poly (mine are rubber).
Thx
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: macmic87] #700806
05/18/10 06:13 PM
05/18/10 06:13 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I have to agree with this,if you tighten everything up with the cars weight off the ground,and then lower the car onto the ground,the weight of the car will torque the bushings and they will squeak. Loosen everything up lower the car until all the weight is on the suspension and retighten. Your squeaking should go away.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: chargervert] #700807
05/18/10 06:49 PM
05/18/10 06:49 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Start with this first before you go and lube anything.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: BDW] #700808
05/18/10 06:58 PM
05/18/10 06:58 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
There are NO moving parts when a rubber bushing is working correctly so there`s no possibility of squeaking. Either you have metal to metal contact somewhere or the thru bolt is loose allowing the inner sleeve to move on the bolt.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Squeaking is driving me crazy (leaf spring bushing) [Re: BDW] #700809
05/19/10 05:37 AM
05/19/10 05:37 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Might be a defective spring- I got one from a vendor last year where the bushing just fell out of the spring! You could push it out with your fingers.
The eye had incorrect fit due to shot blasting pieces being trapped between the end of the eye and the spring. Even after removing them there was not enough tension to hold the factory bushing in place.
I "fixed" it by installing poly bushings since the vendor would not take the springs back unless it was on my dime, a story for another day...
