Six pack linkage question. #700625
05/17/10 04:32 PM
05/17/10 04:32 PM
texas
W
Warrant_Officer Offline OP
W
texas
Just curious, are the outboard linkages supposed to open as you step on the throttle?? is the bolt that ties both outer carb linkages supposed to be tight or lose?? see attachment..
thanks for any help
Re: Six pack linkage question. [Re: Warrant_Officer] #700626
05/17/10 04:56 PM
05/17/10 04:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
they are vacuum operated. You can manually open them by pushing on them while the throttle is up. The rods should be adjusted so that the car idles nice while they are not hooked up and once you hook them up the idle should not change.
Coming soon!!!!
Re: Six pack linkage question. [Re: Mr.Yuck] #700627
05/17/10 04:59 PM
05/17/10 04:59 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Loose
Re: Six pack linkage question. [Re: Mr.Yuck] #700628
05/17/10 05:01 PM
05/17/10 05:01 PM
texas
W
W
texas
The idle is just about right, but was wondering when the outer linkages open, if it was done manually by the throttle linkage or by vacuum ??
again thanks for the help
Re: Six pack linkage question. [Re: Warrant_Officer] #700629
05/17/10 05:17 PM
05/17/10 05:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The long slot in the main carb linkage is to allow the end carbs to stay shut, until the certain vacuum signals allow the secondary carbs to open. The adjustments on both end carbs are made so that they will shut carbs once center carb closes totally.
Re: Six pack linkage question. [Re: buildanother] #700630
05/17/10 05:18 PM
05/17/10 05:18 PM
texas
W
W
texas
Got it..understood..
thanks for the info..
Al
