Re: Tig Welding Practice........
[Re: HardcoreB]
#700420
05/17/10 02:52 PM
05/17/10 02:52 PM
Posts: 146 michigan
tonycpe
michigan
Lookin real good! And for a street car , wow
Old Fogey Racing Ltd.
[Re: STEFF]
#700422
05/17/10 03:09 PM
05/17/10 03:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks good Steff... with some practice you will be able to keep the heat the same(the blue color line) nice job... what ya building now
[Re: Dartman928]
#700428
05/18/10 10:04 AM
05/18/10 10:04 AM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Lookin good. I am trying to learn this very skill myself. My son already has the skills I am tryign to catch up.
[Re: STEFF]
#700429
05/18/10 11:25 AM
05/18/10 11:25 AM
Posts: 2,877 SE Nunya
Bubba
SE Nunya
[Re: Al_Alguire]
#700430
05/18/10 12:43 PM
05/18/10 12:43 PM
Posts: 5,875 communist bloc of new jersey
jamesc
no, no you've got it wrong Al. if he already has the skills what you're supposed to do is deliberately screw up everything you weld and point it out to him. that way he'll take care of all the welding leaving you free to do other things. Bill Cosby once spoke of this principal.
[Re: MR_P_BODY]
#700431
05/18/10 01:13 PM
05/18/10 01:13 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I would bet it's more that he welded in smaller stretches so as to not warp or pull out of alighnment the two parts being welded.
After your done there Steff come down here and finish my junk. Looks good man.
[Re: Leigh]
#700436
05/19/10 09:17 PM
05/19/10 09:17 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
Did you weld it on a jig? My Dana was crooked as a dog's hind leg after welding on it. I would check for sure, before powdercoat. By the way, looks good.
I built a fixture to pre-load the tubes when I welded the back brace on. It worked sweet!! No fixture for final welding the ladder bar brackets etc...
I used the narrowing fixture (centerless ground shaft & mandrels) for welding on the housing ends. They're perfectly inline to the diff bore.
Preload fixture for welding on back brace:
