360 main bearing ? #70022
06/08/08 07:00 PM
06/08/08 07:00 PM
west Michigan
76dart Offline OP
76dart  Offline OP
west Michigan
360 has 2 different main bearing numbers,one is for 71 to73 and one for the other 360s.the bearings are clevites,what is the differents and will a 85 360 crank fit a 73 block?
Re: 360 main bearing ? [Re: 76dart] #70023
06/08/08 07:05 PM
06/08/08 07:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Later bearing and block has a wider thrust surface than the early. The early bearings can be used with no issues in the later block but the later can not be used in the earlier blocks.
Re: 360 main bearing ? [Re: MoparforLife] #70024
06/08/08 10:06 PM
06/08/08 10:06 PM
west Michigan
76dart Offline OP
76dart  Offline OP
west Michigan
thank you very much.
Re: 360 main bearing ? [Re: 76dart] #70025
06/08/08 11:01 PM
06/08/08 11:01 PM
RapidRobert Online content
RapidRobert  Online Content
YES
